either extreme. The elevator is rigged for more up and more down than the
book also but we already covered this one. Definitely need a pull type
breaker handy though.
Al have you tried it in yours?
Steve Rhodes
Moose 173
Sent: Tuesday, January 27, 2004 04:19
Subject: Runaway Trim Forces
elevator.Bob,
Are you saying that with full runaway trim you can't override with
*-------------------------------------------------------------------------*This would not be a failure tolerant system.
Warren
Bob Patterson wrote:
When choosing your button layout, make sure it's difficult to push
the trim by accident - more than a few exciting moments on short final
when the trim was pushed instead of press-to-talk !! Also, it would be
a good idea to have a separate pull-type breaker in an easy-to-reach
spot on the left side panel, for the trim motor - if it ever runs away in
the Moose, there's NO way you could hold it with the stick !!!
(only had ONE good scare - but that's one too many !)
