Moose Tail Mods - vertical stabilizer fairing
Michael Bleau
Post by Michael Bleau » Sat Feb 18, 2012 11:52 am
I seem to recall that someone was producing a vertical stabilizer fairing
for the moose that had increased surface area "increased dorsal fin area"
would this be enough so that the ventral fin and finlets would be
unnecessary.
Subject: Re: Moose Tail Mods - Finlets for float operations
Date: Mon, 12 Jan 2004 13:48:08 -0800
Brad,
Just floats.
Al
Sent: Monday, January 12, 2004 12:55 PM
Is the yaw just on floats or on wheels too? Thanks, Brad
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*.
http://join.msn.com/?page=features/viru ... et%3den-ca
Scott & Leere Aldrich
Post by Scott & Leere Aldrich » Sat Feb 18, 2012 11:52 am
It was Ryan Mowat that had the larger fin fairings. He said on floats their
airplane flew "ugly" with only the larger fin but that all was well after
adding the ventral and the stab tip winglets.
Michael Bleau
Sent: Thursday, January 15, 2004 5:31 PM
Subject: Re: Moose Tail Mods - vertical stabilizer fairing
unnecessary.
Post by Wayne G. O'Shea » Sat Feb 18, 2012 11:52 am
If it is I sure wouldn't want it for tail wheel work in a stiff cross wind!
Ever play on a nasty day with a Stinson... with that oversized tail fin??
Sent: Thursday, January 15, 2004 7:30 PM
unnecessary.
Brad,
Just floats.
Al
http://join.msn.com/?page=features/viru ... %2f%2fjoin
.msn.com%2f%3fpage%3dmisc%2fspecialoffers%26pgmarket%3den-ca
George Coy
Post by George Coy » Sat Feb 18, 2012 11:52 am
Wayne,
Worse than that is a Seabee without a locking tail wheel! I have owned both
Stinsons and SeeBees. The only thing I would point out is that the Rebel has
good brakes as well as a wider gear stance which will give better ground
handling than either of the above designs. I used to have great fun
explaining to students about directional stability in the Stinson. The
Stinson was an airplane that you could step on the rudder, release it and
the airplane would fly sideways. The ball would not return to center unless
you put in some rudder control. It was great for demonstrating neutral yaw
stability.
George
Sent: Thursday, January 15, 2004 7:33 PM
unnecessary.
Brad,
Just floats.
Al
