workbench
workbench
Post by Ralph Baker » Sat Feb 18, 2012 3:04 am
Ben,
MAM says 6 sheets of 3/4 plywood. It can be done with 5 with very
careful layout. I recommend you spring for a "premium" top (2 sheets).
We used birch plywood and have never regretted the extra cost. Use a
plane to get the top edges flat and smooth as required before you put
the top on. Use glue and drywall screws. Put in extra cross braces and
gussets where you think they will aid triangulation. At each on the 6
feet glue in a corner block with a 1/2 - 13 coupling nut so bolts can be
screwed in from the bottom for leveling. Add a shelf underneath for
additional storage. Use the MAM packing crate if you have it for the
table shelf.
Right off, buy a "Smart Level" to assist in leveling the table
construction and many continued uses during further construction. Also
suggest a 4 foot bubble level to use for a flat straight base for the
Smart Level over greater spans as well as any rough leveling.
You will be glad you took the time to construct the build table
accurately.
Elite 624E
PS - We found a 3 shelf materials rack of 2 x 4's and the MAM crate
parts to be useful. It has 4 uprights and 3 - 2 x 4's the long way and
across the ends for shelf supports. Dimensions are 6' high x 8' long x
4' wide. Goes a long way to avoid shop clutter.
workbench
Ben,
I did not cut the bench top to install spring main gear for our
tailwheel Elite. We simply moved the fuselage forward for gear mounting
clearance and it worked fine. Perhaps the Rebel bungee or die spring
main gear will require cuts.
workbench
Post by Wayne G. O'Shea » Sat Feb 18, 2012 3:04 am
That edge overhang can be important as well for clamping stuff down
(especially if you build floats) so don't make the edges of the tabels
"super structure" flush with the top!
Yes Ralph, cut outs through table are required when building the Rebel with
it's "bungee" gear and not required if doing the spring gear as you cut the
leg attach tabs off the gussets before you get to the stage of clamping the
carrythrough cage to the table.
Sent: Thursday, December 04, 2003 10:31 AM
Subject: workbench
Ben,
bscheube
workbench
Post by bscheube » Sat Feb 18, 2012 12:58 pm
Hello to all,
I have purchased a tail kit from Bruce Krist in Florida (SR191). I have been
in touch with Murphy for the upgrade to the 3500. Bruce is going to ship the
tail kit to me at the end of Jan. Anyway my question is about the workbench
that you all are using. Does MAM have plans for this? Or would one of you?
I would like to get going on this ahead of time if I could.
thanks. Bob Scheuber
Al Paxhia
workbench
Post by Al Paxhia » Sat Feb 18, 2012 12:58 pm
Welcome to the group.
There are plans in the manual, but it's a level table 4' X 16'. Most
builders seem to follow the plans, there is no absolute way to build one.
You will want it solid and a comfortable height for you to work.
Al
Moose, N526AP
Sent: Sunday, January 02, 2005 1:51 PM
Subject: workbench
Hello to all,
been
workbench
workbench
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:58 pm
Welcome Bob.
Like Al said.... 4' x 16' table modify the plans a bit to make it two
seperate 4' x 8's that are easy to attach together solidly and an important
thing is to make sure the table top overhangs the edge of the supporting
structure so you can clamp stab/wing spars/etc to the table edge while you
work on them.
Sent: Sunday, January 02, 2005 5:27 PM
Subject: Re: workbench
Al
Moose, N526AP
Subject: workbench
Hello to all,
been
workbench
you?
workbench
Post by Mike Kimball » Sat Feb 18, 2012 12:58 pm
I can scan in the instructions and email them to you. It is just a simple 4
X 16 table made to be sturdy and level. Most people add sheets of plywood
below the table to store stuff as well. Let me know if you want the
instructions.
bscheube@dcsol.com
Sent: Sunday, January 02, 2005 12:51 PM
Subject: workbench
Hello to all,
workbench
Post by Mike Davis » Sat Feb 18, 2012 12:58 pm
I have a PDF file of the workbench plans I made for another builder some
time ago... the file is formatted to the full 11 x 17 size of the original,
so if you print it you may need to make sure it is set to scale to your
paper size. Note that these plans are for the SR2500/Moose and call for a
30" wide table as opposed to the 48" wide table others have recommended...
this is so the fuselage cage can be placed on the table upside down with the
uprights hanging off the sides of the table... but this can easily be
modified to fit your needs.
I've uploaded the file to file area 123 on the archive site... or just hit
"New files".
Subject: workbench
Hello to all,
been
workbench
workbench
I should also mention that I have photos of my completed workbench built to
these plans on my log site... http://n195ak.dcsol.com, under "Workshop",
"Gotta have a work bench!".
Sent: Sunday, January 02, 2005 2:53 PM
original,
"New files".
Subject: workbench
Hello to all,
been
workbench
you?
Mike Betti
workbench
Post by Mike Betti » Sat Feb 18, 2012 12:58 pm
I also have a couple pictures on my website http://bettielite.dcsol.com
under the workshop link. I built it to plan but used high end OSB board
instead of plywood.
Sent: Sunday, January 02, 2005 5:57 PM
original,
recommended...
hit
"New files".
Subject: workbench
Hello to all,
been
ship
workbench
you?
Robert and Olga Johnson
workbench
Post by Robert and Olga Johnson » Sat Feb 18, 2012 12:58 pm
Bob: I would not be to fussy on the quality of wood for the top as you will
end up drilling many holes in it through out the building process. I used
the plywood from Mam's shipping crate when I built my bench and have since
flipped it over to build a 2nd Rebel.( the top that is) A sturdy and flat
table are the more important issues. Bob J formerly Rebel 652 - currently
Rebel 725
Sent: Sunday, January 02, 2005 4:51 PM
Subject: workbench
Hello to all,
been
workbench
Reed Britt Civ OO-ALC/MAD
workbench
Post by Reed Britt Civ OO-ALC/MAD » Sat Feb 18, 2012 12:58 pm
Bob - I used the shipping box, Appx 4'x4'x16' - added two 9" TJI (silent
floor composite joists)along the length because they are about perfectly
true(about $1.14 per foot) - added steel studs 24"oc in the other direction
and the two 4'x8' sheets of OSB - Put the whole box on wheels and have a
3/8" bolt upside down turning in the blind nut that is embedded in the TJI -
This levels the table -
It served as a great storage box for those delicate skins and misc but not
real convenient to get in and out of -
Britt - SR194
G. O'Shea
Sent: Sunday, January 02, 2005 4:33 PM
Welcome Bob.
work on them.
Al
Moose, N526AP
Subject: workbench
Hello to all,
been
workbench
you?
bscheube
workbench
thanks for the info. Mike if you could scan and e-mail that would be great.
bscheube@direcpc.com
On 1/2/2005 2:40 PM, MKIMBALL@GCI.NET wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Sun, 02 Jan 2005 14:37:47 -0900
-> Received: from hermes.acsalaska.net ([209.112.155.38])
EHLO=hermes.acsalaska.net
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 230059671; Sun, 02 Jan 2005 14:37:45 -0900
-> Received: from mikespc (209-193-47-2-cdsl-rb1.fai.acsalaska.net
[209.193.47.2])
-> by hermes.acsalaska.net (8.13.1/8.13.1) with SMTP id j02NbhHC008797
-> for <rebel-builders@dcsol.com>; Sun, 2 Jan 2005 14:37:43 -0900 (AKST)
-> (envelope-from mkimball@gci.net)
-> From: "Mike Kimball" <mkimball@gci.net>
-> Subject: RE: workbench
-> Date: Sun, 2 Jan 2005 14:40:16 -0900
-> Message-ID: <000001c4f124$6994e9a0$0700a8c0@mikespc>
-> X-Orig-MIME-Version: 1.0
-> X-Priority: 3 (Normal)
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
-> Importance: Normal
-> In-Reply-To: <1104702663@dcsol.com>
-> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2800.1409
-> X-ACS-Spam-Status: no
-> X-ACS-Scanned-By: MD 2.44; SA 2.64; spamdefang 1.109
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> I can scan in the instructions and email them to you. It is just a simple 4
-> X 16 table made to be sturdy and level. Most people add sheets of plywood
-> below the table to store stuff as well. Let me know if you want the
-> instructions.
-> Mike
-> -----Original Message-----
-> From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of
-> bscheube@dcsol.com
-> Sent: Sunday, January 02, 2005 12:51 PM
-> Subject: workbench
-> Hello to all,
-> I have purchased a tail kit from Bruce Krist in Florida (SR191). I have been
-> in touch with Murphy for the upgrade to the 3500. Bruce is going to ship the
-> tail kit to me at the end of Jan. Anyway my question is about the workbench
-> that you all are using. Does MAM have plans for this? Or would one of you?
-> I would like to get going on this ahead of time if I could.
-> thanks. Bob Scheuber
-> List archives located at: https://www.dcsol.com/login?mode=HTML
-> Subscription services located at:
-> https://www.dcsol.com/public/code/html-subscribe.htm
workbench
https://www.dcsol.com/file/area123/workbench.pdf
Sent: Monday, January 03, 2005 2:54 PM
great.
charles eubanks
Workbench
Post by charles eubanks » Sun Feb 19, 2012 1:26 pm
To All
If I get this posted right, this will be my first time on the Rebel net. I
would appreciate your patience. I am waiting now for a estimated mid March
delivery of my Rebel kit, SN/802R. The workbench drawing is the only info I
have received so far. I thought I would get started on it but, in the
interest of conserving floor space in my shop, I am wondering if the
workbench need be the full 4Ft.x16Ft. Or would something smaller work just
as well. Thanks
Charlie E. 802R
