crack on sleeve,when I phoned Darrell at Warp Drive he said to continual
flying and he would send me two new blades. He also said not to idle engine
down for long period of time,keep rpm. up to approx. 1000. I have my Warp
Drive on a 0-360 in my Rebel on edo 2000 floats, the crack appeared at about
300 hrs. I have about 400 hrs now and the two oldest blades have not cracked
and the two new ones are fine so far,approx. 100 hrs. on two blades. I
talked to Darrell on Friday Nov. 28 and he said he has not seen any
delaminating. I hope this helps a little
THANKS
jerry
Sent: Monday, December 01, 2003 4:50 PM
Subject: Warp Drive prop
*-------------------------------------------------------------------------*I can't remember hearing of a Warp Drive blade failure (de-laminating)
on a 150 hp Lycoming. I thought it was only the higher compression 160
hp version ... Is that still correct today?
Are many of you still flying the 150 hp Warp Drive combo?
Clay
