Pro Seal
Pro Seal
Received: from home.com ([24.112.112.153]) by mail.rdc1.bc.wave.home.com
(InterMail v4.00.03 201-229-104) with ESMTP
id <19990218013108.LRYV19434.mail.rdc1.bc.wave.home.com@home.com>
for <murphy-rebel@dcsol.com>; Wed, 17 Feb 1999 17:31:08 -0800
Message-ID: <36CB6D4A.CD92A31C@home.com>
Date: Wed, 17 Feb 1999 17:30:50 -0800
X-Mailer: Mozilla 4.5 [en]C-AtHome0402 (Win98; I)
X-Accept-Language: en
MIME-Version: 1.0
To: Murphy Mailing List <murphy-rebel@dcsol.com>
Subject: Pro Seal
I'm ready to rivet my bottom wing/tank skin. My work area is outdoors
and unheated. The temperatures are ranging from 3c-10c. I can't seem
to find any data on the working temperatures for the Pro-seal.
Will I be alright using it at these temps, or do I need to try and heat
the carport?
Vancouver, BC
MIME-Version: 1.0
Subject: Pro Seal
the carport?
Vancouver, BC
Pro Seal
Received: from [137.186.227.199] (helo=ms02-199.tor.istar.ca)
for murphy-rebel@dcsol.com
id 10DKcl-0005iV-00; Wed, 17 Feb 1999 22:59:39 -0500
Mime-Version: 1.0
Subject: Re: Pro Seal
Message-Id: <E10DKcl-0005iV-00@mail2.toronto.istar.net>
Date: Wed, 17 Feb 1999 22:59:39 -0500
It WILL cure at those temps, BUT - it will take a LOOOOOONGGGGGGG
time !! (Like - maybe hard by half-past JUNE !)
Probably better to arrange for some heat ....
It will be so thick that you'll likely want to pull everything
together very slowly, to give it time to squeeze out. There are
several schools of thought on this ;-) .....
One is to set the air pressure on your rivet gun way down to
maybe 20 or 30 lb, and only partly pull all the rivets, then go around
again at a higher pressure, until you get high enough to snap them -
this has worked for some folks (and not for others !!)
You might want to review the list archives - there has been a
LOT of comment on proper cleaning/preparation, etc...
....bobp
----------------------------orig.------------------------------------
Mime-Version: 1.0
....bobp
the carport?
Vancouver, BC
Pro Seal
Received: from the-benson-s (209-122-196-50.s50.tnt5.lnh.md.dialup.rcn.com
[209.122.196.50])
by smtp2.erols.com (8.8.8/8.8.5) with SMTP id HAA03841
for <murphy-rebel@dcsol.com>; Thu, 18 Feb 1999 07:58:56 -0500 (EST)
Message-ID: <003601be5b3d$f54f4c20$32c47ad1@the-benson-s>
Date: Thu, 18 Feb 1999 07:55:25 -0500
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Dave:
The PRC Pro-Seal instruction sheet I have says that you have about 4 hours
to apply the B-4 mixture at 75 F and 50% relative humidity. The mixture
should be tack free in about 36 hours. "For every 10F to 15F rise in
temperature, application life is reduced by half, and for every 10F to 15F
drop it is approximately doubled. The temperature/time relationship is
approximately the same for curing as it is for application life. Cure of
sealant below 55F may be greatly retarded. Cure my be hastened by applying
heat up to `130F."
I hope that this helps.
Lonnie Benson - R171
Date: Wednesday, February 17, 1999 8:31 PM
Subject: Pro Seal
[209.122.196.50])
MIME-Version: 1.0
X-Priority: 3
Dave:
heat up to `130F."
Subject: Pro Seal
the carport?
Vancouver, BC
Pro Seal
Received: from tim-toshiba - 206.40.8.15 by email.msn.com with Microsoft
SMTPSVC;
Mon, 22 Feb 1999 10:38:53 -0800
Reply-To: <tlcarter@email.msn.com>
To: "'Murphy Rebel'" <murphy-rebel@dcsol.com>
Subject: RE: Pro Seal
Date: Mon, 22 Feb 1999 10:23:02 -0800
Message-ID: <000001be5e93$37d8a160$14640a0a@tim-toshiba>
MIME-Version: 1.0
X-Priority: 3 (Normal)
X-Mailer: Microsoft Outlook 8.5, Build 4.71.2173.0
Importance: Normal
In-Reply-To: <36CE2CEA.CD8@gte.net>
Return-Path: tlcarter@email.msn.com
Mickey:
I would think that excess front spar towards the root is not a bad
thing....here is why...
That is where the front attach bracket assembly is put on the wing, where
the W158 (I think) bracket uses two 1/4" bolts and a packer to attach the
front spar, front spar front doubler, front spar rear doubler and front
attach brackets all together to the front root rib.
On my RH wing the front spar pilot holes had evidently slipped somewhat in
MAM's turret punch when they made it, and the entire hole set was shifted
towards the root. With the pilot holes shifted that direction this left me
only the very minimum edge distance (3/16" per Darryl Murphy) from the edge
of the holes for the two vertical 1/4" bolts that pass thru that whole
assembly to the edge of the spar.
Net-net is...if I am understanding your message correctly, I think more is
better if there is more towards the root...but, based on needing a full 12'
of material for the wing, you should not have more than about 1/8" - 3/16"
excess, and I'd be surprised if it were that much.
I would not trim it.
Tim
Sent: Friday, February 19, 1999 7:33 PM
To: (Murphy Rebel)
Tim Carter wrote:
I'm peddeling as fast as I can to catch up with you guys. I am
currently on the right main wing trying to get the front spar to fit. It
seems when I line up the tip end of the spar with the nose rib flange,
there is some excess spar on the root end. The root end nose rib does
not line up with the edge of the spar. Does this have to be trimed off.
Mickey
#534
SMTPSVC;
MIME-Version: 1.0
Importance: Normal
Mickey:
Tim
To: (Murphy Rebel)
Tim Carter wrote:
bringDave:
It looks like we are about at the same spot in our build.
Good luck with sealing the second tank!
I too am looking forward to the fuselage...a big break from the 'wings'
portion of my life!
Tim
#438
Sent: Friday, February 19, 1999 6:29 PM
To: (Murphy Rebel)
I spent today rivetting the bottom wing skin on. That's exactly how I
decided to do it.. I put a couple 60w bulbs underneath for a couple hours
to bring the tank section up to temp. And I'll leave them in there until
tomorrow sometime.. You are right, the lamps are more than enough to
Timall the metal up to a nice temperature.
Finally! I'm almost ready to get this second wing off the bench and get
started on the Fuselage!
I've already assembled the fuselage floor and some of the uprights on a
smaller table in the workshop, but I can't do any more on it in the
workshop, there just isn't enough room.
I went through the same thing with minimal temperatures, speeded the
curing by putting a low wattage incandescent light bulb inside the fuel
tank, watched it for a while and it never got more than warm to the
touch so I left it overnight.
Mickey
#534
Pro Seal
Received: from sunshine (2Cust25.tnt7.hou3.da.uu.net [153.36.227.25])
by smtp2.gte.net with SMTP id SAA22973
for <murphy-rebel@dcsol.com>; Mon, 22 Feb 1999 18:06:02 -0600 (CST)
Message-ID: <36D1F07C.6080@gte.net>
Date: Mon, 22 Feb 1999 18:04:12 -0600
X-Mailer: Mozilla 3.0 (Win95; I)
MIME-Version: 1.0
References: <000001be5e93$37d8a160$14640a0a@tim-toshiba>
Tim Carter wrote:
Thanks for the relpy. I agree with your thought on the extra spar not
being trimed off. It is however a little more than 1/8", more like 1/4"
to 3/8". The only prob I have with leaveing it on is how do I get the
measurement for the w119 front attach bracket? the book calles for the
spar to be placed next to a block of wood with the center line drawn
from the spar onto the block. The critical measurement is the distance
'A' from the edge of the rear spar to the center of the rear spar attach
brackett hole. If I do this it shifts the spar to the left and the
excess is now at the tip end with the pre drilled holes no longer
lineing up with the outboard nose rib. I quess i could drill a new set
of holes at the tip end were they should go. What do you think?
Thanks again.
#534 Mickey
MIME-Version: 1.0
Tim Carter wrote:
meMickey:
edgeonly the very minimum edge distance (3/16" per Darryl Murphy) from the
12'of the holes for the two vertical 1/4" bolts that pass thru that whole
hoursof material for the wing, you should not have more than about 1/8" - 3/16"
Tim
To: (Murphy Rebel)
Tim Carter wrote:Dave:
portion of my life!
Tim
#438
To: (Murphy Rebel)
untilto bring the tank section up to temp. And I'll leave them in there
fuelbringtomorrow sometime.. You are right, the lamps are more than enough toall the metal up to a nice temperature.
Tim,Timtank, watched it for a while and it never got more than warm to the
Mickey
#534
Thanks again.
#534 Mickey
Pro Seal
by smtp2.gte.net with SMTP id SAA09927
for <murphy-rebel@dcsol.com>; Mon, 22 Feb 1999 18:29:27 -0600 (CST)
Message-ID: <36D1F5FA.779@gte.net>
Date: Mon, 22 Feb 1999 18:27:38 -0600
MIME-Version: 1.0
References: <001501be5ec2$b9060b40$14640a0a@tim-toshiba>
Tim Carter wrote:
Mickey
MIME-Version: 1.0
Tim Carter wrote:
Rebel/RebelMickey:
I see your problem...
As I recall, I got MAM to send me these procedures from the new
whereElite manual...and they were much clearer on an alternative way to do
this...
I recommend at this point to give them a call and talk it over with them.
This is a critical area so I'd seek their advice.
Tim
Sent: Monday, February 22, 1999 4:04 PM
To: (Murphy Rebel)
Tim Carter wrote:Mickey:
thethe W158 (I think) bracket uses two 1/4" bolts and a packer to attach
infront spar, front spar front doubler, front spar rear doubler and front
shiftedMAM's turret punch when they made it, and the entire hole set was
ismetowards the root. With the pilot holes shifted that direction this leftedgeonly the very minimum edge distance (3/16" per Darryl Murphy) from theof the holes for the two vertical 1/4" bolts that pass thru that whole
3/16"12'better if there is more towards the root...but, based on needing a fullof material for the wing, you should not have more than about 1/8" -
'wings'excess, and I'd be surprised if it were that much.
Tim
To: (Murphy Rebel)
gethoursportion of my life!
Tim
#438
To: (Murphy Rebel)
decided to do it.. I put a couple 60w bulbs underneath for a coupleuntilto bring the tank section up to temp. And I'll leave them in therebringtomorrow sometime.. You are right, the lamps are more than enough toall the metal up to a nice temperature.
astarted on the Fuselage!
Thanks Tim, I will do that.fuelsmaller table in the workshop, but I can't do any more on it in the
Tim,Tim
Mickey
#534
Thanks again.
#534 Mickey
Mickey
pro seal
Received: from tim - 209.119.137.69 by email.msn.com with Microsoft SMTPSVC;
Mon, 19 Jul 1999 11:49:09 -0700
Reply-To: <tlcarter@msn.com>
To: "'Murphy Rebel Builders List'" <murphy-rebel@dcsol.com>
Subject: RE: pro seal
Date: Mon, 19 Jul 1999 12:03:25 -0700
Message-ID: <000601bed219$6362fe80$14640a0a@tim>
MIME-Version: 1.0
Importance: Normal
X-MimeOLE: Produced By Microsoft MimeOLE V5.00.2314.1300
In-Reply-To: <E7D1F2B88F8ED1119174080009DC2612224CDE@tvfrmail>
Yes. It will have a little bit of tack when it has first set up, and it
will be dark grey, almost black. Over time as it cures more, it will become
less tacky, and become slightly more grey.
I highly recommend using a scale to mix the proper amounts of base and
hardner.
10 base to 1 hardner.
Tim
From: Snader, Douglas E. [mailto:snaderde@tvfr.com]
Sent: Monday, July 19, 1999 11:29 AM
To: 'murphy-rebel@dcsol.com'
Subject: pro seal
Is pro seal supposed to dry to a rubbery,non-tacky finish?
MIME-Version: 1.0
Importance: Normal
hardner.
Tim
Subject: pro seal
Jones, Michael
pro seal
hi guys
so i notice on the label for pro seal to mix it says 10 catalyst and 100
base, is this not the same as 1 to 10 ?? I notice wayne listed it this way
on last night postings ??
Whats the deal ??
mike #007
Whats the deal ??
mike #007
pro seal
Mike it's mixed 10 parts base to 1 part catalyst by WEIGHT and I believe 8.7
base to 1 catalyst by volume (but I always weigh it on a digital scale so
can't remember for sure if that is the correct volume ratio). I only listed
100 to 10 last night as that is how much I needed to use. That's still 10 to
1 ratio x 10!
Mix how ever much you want, but always in the correct ratio.
Sent: Thursday, June 12, 2003 7:18 AM
Subject: pro seal
1 ratio x 10!
Subject: pro seal
*-------------------------------------------------------------------------*hi guys
Whats the deal ??
mike #007
Jones, Michael
pro seal
thanks wayne, i also am using 3 beam scale so should be accurate
mike
From: Wayne G. O'Shea [mailto:oifa@irishfield.on.ca]
Sent: Thursday, June 12, 2003 8:48 AM
Subject: Re: pro seal
1 ratio x 10!
Subject: pro seal
mike
1 ratio x 10!
Subject: pro seal
Whats the deal ??
mike #007
pro seal
If you are ever off on anything, make sure it's a little extra cataylst.
That way it will still harden and maybe even slightly quicker.
Sent: Thursday, June 12, 2003 8:52 AM
8.7thanks wayne, i also am using 3 beam scale so should be accurate
mike
listedbase to 1 catalyst by volume (but I always weigh it on a digital scale so
to100 to 10 last night as that is how much I needed to use. That's still 10
way1 ratio x 10!
Subject: pro seal
hi guys
*-------------------------------------------------------------------------*on last night postings ??
Whats the deal ??
mike #007
Jones, Michael
pro seal
always done that, even with fiberglass and bondo on my old cars
Sent: Thursday, June 12, 2003 9:14 AM
mike
way1 ratio x 10!
Subject: pro seal
hi guys
Whats the deal ??
mike #007
LisaFly99
pro seal
In a message dated 6/12/03 7:53:58 AM Central Daylight Time, MJones@hatch.ca
writes:
On the triple beam I used tuna fish cans for mixing in. Wash them up then
wipe them down with MEK or paint thinner and they're clean as a wistle. Wiegh
in at aprox 26 grams tar. And if you git a plastic cat food can cover you can
store the unused Pro Seal in the fridge over night.
Phil&Lisa Smith
#460R
N414D
writes:
MIKEthanks wayne, i also am using 3 beam scale so should be accurate
Phil&Lisa Smith
#460R
N414D
Pro Seal
Steve,
There are several cure times available. Also, if I remember correctly,
the cure time is base at 70 degrees F and halves for each 10 degrees
above that. There is a brush grade and a "peanut butter" grade as well.
Depends on what you are using it for. Some say to thin with MEK but I
don't like to alter the factory chemistry. I will try to remember to
get the info tomorrow from the cans at my hangar. I can't help with SR
quantities but do get latex gloves and at least a gross of small "acid
brushes" about 1/2" across.
Elite 624E
Elite 624E
Terry Dazey
Pro Seal
Don't forget the "double latex glove" trick! When you are preparing for Pro
Sealing, put on 2 pair of gloves. When the outside gloves get too messy,
pull them off, toss them in the trash and put on a new pair of clean gloves
over the first pair. Works great.
