Did this plane have the edges rolled or flanged? It
sort of looked like that as best I could tell from the
pics. Were you planning to also roll the edges again
after the doubler?
Also, do you know what is causing those star cracks on
the windshield? Is it flexing?
As it happens, I just got a new windshield from MAM,
too. I don't plan on putting it in right away, but
wanted to have one on hand if I needed it. I do have a
couple of cracks on the bottoms where I had drilled
bolt holes to attach. Mine was an early install,
whereas I understand now, that you make them float
without any bolt attachments which is what I will do
next time.
I think floats put quite a bit of extra stress around
the windshield area. I saw one of my cracks happen
during a rough water landing. There are about 2 seconds
of beating that you have to endure just as you come
down from the step in big waves, or at least I haven't
figured out yet how to avoid that.
So sooner or later I will be replacing my windshield.
http://www.dcsol.com:81/public/code/html-subscribe.wcx-----Original Message-----
Sent: Tuesday, April 29, 2003 5:36 PM
Subject: Skylight holes - Today's "From the Hanger"
Another "from the hanger" for you!!
Pulled Howard's windshield today to install
a new one, since his is full of
little star cracks that show up when flying
into the sun.
Found that both of his forward skylight
holes (that are under the windshield
area) have cracks growing out of each corner
of the holes. Passenger side
has 4 cracks and the pilot side 3.
I posted two pics to Rebel - Fuselage.
My plan of attack is to fabricate .025
doubler rings to fit to the underside
of these skylight holes (just like the
backing plates I use for all the
other holes with Lexan in them) and rivet
same with C/S rivets to insure
windshield clearance without rubbing on any
rivet heads.
I WOULD HIGHLY SUGGEST TO ANYONE THAT IS
BUILDING MURPHY METAL
(Rebel/Elite/SR/Moose) to do these doublers
now, before you do your paint
job and install your windshield.
If this has happened to a low time Rebel on
floats, then it's only
elementary that it is going to happen to the
entire "Rebel" line sooner or
later in your flight "enjoyment"! Easier to
nip it before they start!
Archives located at
