How much Pro Seal?
S & L Aldrich
How much Pro Seal?
Post by S & L Aldrich » Sat Feb 18, 2012 1:21 am
Randy, Don, anybody,
Approximately how much of the brush able PS 890 is enough for fixing the quick build leaks? Pint kit or Qt?
Scott Aldrich
N174SL Moose #174
klehman
How much Pro Seal?
Post by klehman » Sat Feb 18, 2012 1:21 am
Scott
I coated all the interior joints and rivets on a 3 bay Rebel tank with a
3.5 oz. semkit of brushable.
Scott Aldrich
N174SL Moose #174
RJBWoodman
How much Pro Seal?
Post by RJBWoodman » Sat Feb 18, 2012 1:21 am
If you have quite a few leaks per tank as we did, you will need to brush all the seams, joints, rivets, stringers, etc of the tank interiors. If this is the case we used 3 pints total for the brushing process only. Thats after 2 pints of putty meticulously working possible leak by possible leak. Its not fun. ( Wish i was done ) I have my final pint to go out and finish the job. If you have a couple leaks, know where they are, i think you should brush one pint per tank as a final "seal all" coating for a perfect job. Good luck.
Randy Bowers SR130
