Rebel Progress
scott.hibbs
Rebel Progress
Post by scott.hibbs » Sat Feb 18, 2012 1:08 am
Just a progress report. I finally have positioned and drilled the seat
rails. What a great feeling to sit inside and make engine noises. Next is
making some access plates and running the elevator cables.
Scott Hibbs
hibbs@pacifier.com
Murray & Carol
Rebel Progress
Post by Murray & Carol » Sat Feb 18, 2012 1:12 am
Hello Scott
Although I'v put my cable guides in place we're at the same stage. I used 7
guides on each side for the rudder and 14 down the middle for the elevator
cables. May seem like overkill but I wanted to take as much slop out of the
cables as possible.
Good luck, lets keep at it.
Murray Cherkas
REBEL 505
C-GKNN
Where do live?
scott.hibbs
Rebel Progress
Post by scott.hibbs » Sat Feb 18, 2012 1:13 am
Murray, did you find that you had too much binding with the 14 guides? More
is better unless the extra friction is too noticable. I live in Vancouver, WA
(near Portland, OR).
Scott
-> Hello Scott
-> Although I'v put my cable guides in place we're at the same stage. I used 7
-> guides on each side for the rudder and 14 down the middle for the elevator
-> cables. May seem like overkill but I wanted to take as much slop out of the
-> cables as possible.
-> Good luck, lets keep at it.
-> Murray Cherkas
-> REBEL 505
-> C-GKNN
-> Where do live?
Murray & Carol
Rebel Progress
Post by Murray & Carol » Sat Feb 18, 2012 1:13 am
Hi Scott:
The 14 guides up the centre,7 for each cable.
If installed according to the manual I felt they would rub. There is a high
point at bulkhead F so I put one at the high point. The manual also shows
one about 18" in front of the pulleys at the end of the floor. I felt that
the cables would sag here and rub on the floor so I put one just in front of
the pulleys.The first guide aft of the control column results in quite a
change of direction so I put this 1st guide a little further back. The rest
of the guides hold the cable up in the event of a little slack in the cable.
This I hope will allow me to not make the cable so tight. The longer the
distance between guides the tighter the cable has to be to prevent a
sagging cable rubbing the floor. I don't think there is any more friction
with more guides as they are all straight with no side friction.
Good luck
Murray Cherkas
REBEL 505
Murray & Carol
Rebel Progress
Hi Scott
I may be comming that way in July and would like to stop by and see your
rebel if you might not mind.
Lets keep in touch.
Murray Cherkas
REBEL 505
scott.hibbs
Rebel Progress
Murray, that would be great. My home number is 360-546-0389.
Scott
-> Hi Scott
-> I may be comming that way in July and would like to stop by and see your
-> rebel if you might not mind.
-> Lets keep in touch.
-> Murray Cherkas
-> REBEL 505
