SR3500 Fus-409/Pulley BB-128
Hi guys and gals!
Now for something totally different! I have a question for you SR builders,
that I would like some replies to! Looks like it's time for me to get some
list usage the other way, with this new project underway!
I am sorting out all the stuff that is done and still needs to be done to
this SR2500/3500 I have come to own, so I can start "tearing" into it.
Before I go drilling those big 1/2" cable clearance holes through the fins
front attach bracket (scary looking stuff aye!) I have noticed that the two
BB-128 pulleys that are mounted to the Fus-409 brackets are so big in
diameter that the previous builder had to shim the brackets out from the
bulkhead for the pulleys to clear it enough to roll and that the predrilled
cotter pin (cable retainer) holes are not useable. There is not enough
material, out far enough, to drill new cotter holes. I think I remember
seeing a note from Elaine in shipping about a change in pulley diameters
from old stock to new stock that may have been addressing this, but I can't
find it. What have those of you that are beyond this point ran into here??
Change of pulleys, mfg new brackets, extend the top bracket tab with a
couple add ons to allow for a new cotter hole, or ??.
Sasquatch #017
..... and many, many Rebels!
Sasquatch #017
Hi Wayne,
Well as I best remember, the folks at MAM said they discontinued the smaller
pulley and I was short one. Then I received a larger FUS409 bracket and
larger pulleys, the larger bracket and pulleys did not align with the hole
in the fin. I used the original smaller 409 and ordered a smaller pulley
from Aircraft Spruce. All went together OK we will see how it works.
Al
SR#26
Sent: Monday, January 14, 2002 6:15 PM
Subject: SR3500 Fus-409/Pulley BB-128
Al
SR#26
builders,Hi guys and gals!
twothat I would like some replies to! Looks like it's time for me to get some
predrilledBB-128 pulleys that are mounted to the Fus-409 brackets are so big in
can'tcotter pin (cable retainer) holes are not useable. There is not enough
**find it. What have those of you that are beyond this point ran into here??
Sasquatch #017
**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself
**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm
**** To contact the list admin, e-mail mike.davis@dcsol.com
Al, thanks! That is what I figured and maybe I should dig a little harder
through all the boxes and see if there is another set of FUS-409's here. I
don't think there are though, so I will check through my pulley stock in my
NOS stuff and see if I have some with a smaller O.D. so I can use the cotter
hole and a similar 1.9" cable groove diameter so no extra stress on the
cables. I noticed that these BB-128 pulleys have a really deep side wall, so
there must be a pulley with a smaller O.D and the same cable groove
diameter. Just don't want to drill those 1/2" holes through the fin attach
at the current location and then change pulleys and have to make them into
slots!
Sent: Monday, January 14, 2002 10:34 PM
Subject: Re: SR3500 Fus-409/Pulley BB-128
slots!
smallerHi Wayne,
somepulley and I was short one. Then I received a larger FUS409 bracket and
Al
SR#26
Now for something totally different! I have a question for you SRthat I would like some replies to! Looks like it's time for me to get
tolist usage the other way, with this new project underway!
finsthis SR2500/3500 I have come to own, so I can start "tearing" into it.
here??twofront attach bracket (scary looking stuff aye!) I have noticed that thepredrilledBB-128 pulleys that are mounted to the Fus-409 brackets are so big in
bulkhead for the pulleys to clear it enough to roll and that thecan'tcotter pin (cable retainer) holes are not useable. There is not enough
from old stock to new stock that may have been addressing this, but Ifind it. What have those of you that are beyond this point ran into
****Change of pulleys, mfg new brackets, extend the top bracket tab with a
Sasquatch #017
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself**** Archives located at http://rebel:builder@www.dcsol.com:81/default.htm**** To contact the list admin, e-mail mike.davis@dcsol.com
This surprises me because I have serial number 44 which I bought almost 5
years ago from MAM which is a pretty early kit and I had no trouble at all.
The brackets, pulleys, hole alignment all worked fine.
SR#044
Sent: Monday, January 14, 2002 6:52 PM
slots!
SR#044
slots!
smallerHi Wayne,
Al
SR#26
Sasquatch #017
Wayne,
According to our manual (circa 21/06/99) and shipping list,
we are to use the BB-128, which we have listed as MS24566-3B on shipping
list, with the FUS 409 brackets We put everything together without any
problems and our holes for the cotter pin (cable retainer) have enough
clearance.
And of course, if this has changed in latest manuals we have not heard about
it...
P & M
SR003
Sent: Monday, January 14, 2002 9:15 PM
clearance.
it...
P & M
SR003
Sasquatch #017
Thanks guys and Monica!
Making sense now by the serial number "range". The packing slip spells out
BB-128's which are 1.9" diameter at the cable and 2.5" overall, but
Peter/Monica's early kit #003 was shipped with MS24566-3B's that are only
1.5" at the cable and 2" overall. The kit I have (that was Dr. Rob Helt's)
is serial #17 and it was shipped with the BB-128's and the older smaller
Fus-409's. I guess somewhere in there people tipped off MAM and they started
making larger Fus-409's to go with the larger diameter BB-128's. I guess Rob
never asked for the new Fus-409's, as I don't see them here, so I will make
my own up and stay with the larger pulley for less cable stress.
Regards,
Sent: Tuesday, January 15, 2002 3:56 PM
Regards,
aboutWayne,
clearance.
someit...
P & M
SR003
Sasquatch #017
I have SR 087. My pulleys are of the larger diameter and require either a
larger bracket or a shim. I haven't yet actually mounted my pulleys. So I may
look for smaller ones, to avoid extra holes in the fin mount.
Don
On Tue, 15 Jan 2002 11:07:32 -0900 Mike Kimball <mkimball@gci.net> wrote:
Donald E. Cormack
Vice Dean,
School of Graduate Studies, and
Professor of Chemical Engineering
65 St. George Street
University of Toronto
Toronto, Canada M5S 2Z9
Tel: (416)978-2384 FAX: (416)978-1649
donald.cormack@utoronto.ca
Don
----------------------This surprises me because I have serial number 44 which I bought almost 5
SR#044
slots!
smallerHi Wayne,
Well as I best remember, the folks at MAM said they discontinued thesomepulley and I was short one. Then I received a larger FUS409 bracket and
Al
SR#26
Now for something totally different! I have a question for you SRthat I would like some replies to! Looks like it's time for me to gettolist usage the other way, with this new project underway!
I am sorting out all the stuff that is done and still needs to be donefinsthis SR2500/3500 I have come to own, so I can start "tearing" into it.
Before I go drilling those big 1/2" cable clearance holes through thehere??twofront attach bracket (scary looking stuff aye!) I have noticed that thepredrilledBB-128 pulleys that are mounted to the Fus-409 brackets are so big in
from old stock to new stock that may have been addressing this, but Ifind it. What have those of you that are beyond this point ran into****Change of pulleys, mfg new brackets, extend the top bracket tab with a
Sasquatch #017
Donald E. Cormack
Vice Dean,
Don, sounds like MAM has a larger set (of Fus-409's) for the asking, why not
check that out and go with the larger pulleys you have if you haven't
drilled the holes through the fin mount yet!? Probably what I should do also
(or make my own) as I haven't drilled the holes through the fin bracket, but
the Fus-409 pulley brackets are already drilled and cleco'd in place at
3/32".
Have you put a pulley, bolt and bracket pair together, to see if in fact you
don't already have the larger Fus-409's?
Regards,
Cc: <murphy-rebel@dcsol.com>
Sent: Tuesday, January 15, 2002 6:10 PM
Subject: Re: RE: SR3500 Fus-409/Pulley BB-128
3/32".
Regards,
mayI have SR 087. My pulleys are of the larger diameter and require either a
5look for smaller ones, to avoid extra holes in the fin mount.
Don
all.years ago from MAM which is a pretty early kit and I had no trouble at
harderThe brackets, pulleys, hole alignment all worked fine.
SR#044
Ithrough all the boxes and see if there is another set of FUS-409's here.
mydon't think there are though, so I will check through my pulley stock in
cotterNOS stuff and see if I have some with a smaller O.D. so I can use the
wall, sohole and a similar 1.9" cable groove diameter so no extra stress on the
attachthere must be a pulley with a smaller O.D and the same cable groove
intoat the current location and then change pulleys and have to make them
andslots!
smallerHi Wayne,
Well as I best remember, the folks at MAM said they discontinued thepulley and I was short one. Then I received a larger FUS409 bracket
holelarger pulleys, the larger bracket and pulleys did not align with the
pulleyin the fin. I used the original smaller 409 and ordered a smaller
getfrom Aircraft Spruce. All went together OK we will see how it works.
Al
SR#26
builders,
donesome
it.to
thefins
intwo
enoughpredrilled
remember
diameters
ahere??can't
itself**
http://rebel:builder@www.dcsol.com:81/default.htm****** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself** Archives located at
******** To contact the list admin, e-mail mike.davis@dcsol.com
Donald E. Cormack
Vice Dean,
Didn't go the first/second time due to the server problems!
Sent: Tuesday, January 15, 2002 11:01 PM
Subject: RE: SR3500 Fus-409/Pulley BB-128
either
notDon, sounds like MAM has a larger set (of Fus-409's) for the asking, whyalsocheck that out and go with the larger pulleys you have if you haven't
drilled the holes through the fin mount yet!? Probably what I should dobut(or make my own) as I haven't drilled the holes through the fin bracket,youthe Fus-409 pulley brackets are already drilled and cleco'd in place at
3/32".
Have you put a pulley, bolt and bracket pair together, to see if in factdon't already have the larger Fus-409's?
Regards,
Soalarger bracket or a shim. I haven't yet actually mounted my pulleys.
atIwrote:maylook for smaller ones, to avoid extra holes in the fin mount.
Don
On Tue, 15 Jan 2002 11:07:32 -0900 Mike Kimball <mkimball@gci.net>almost5
Behalfall.
stockOfhere.harderI
theinmy
themthecotterwall, soattach
theinto
bracket
SRtheandworks.holepulley
beget
intodone
throughit.
bigthatthethe
withfrominbuttheenoughrememberdiametersintoIwitha
itself
itself
http://rebel:builder@www.dcsol.com:81/default.htmhttp://rebel:builder@www.dcsol.com:81/default.htm********----------------------
Donald E. Cormack
Vice Dean,
** To unsubscribe, send e-mail to list-server@dcsol.com with**** UNSUBSCRIBE MURPHY-REBEL in the message body on a line by itself** Archives located at
