Pump for Murphy 1800 pump-outs
Post by Walter Klatt » Fri Feb 17, 2012 9:16 pm
My floats are almost ready to take flight, so it is time to get a paddle and
a pump for the pump-out holes. Any suggestions for the pump? I noticed these
holes are smaller than the ones I've seen on other float planes. Is this
something you can buy at a local Canadian Tire or boat shop?
Post by Bob Patterson » Fri Feb 17, 2012 9:16 pm
Hi Walter !
Yep ! Not all Canadian Tire stores have 'em, but they should,
out your way. If not, a boat shop definitely will. The ends of the
pump have a tapered fitting, so should fit the pump-outs easily.
I bought a pair of the heavy plastic paddles that disasemble into
2 parts because they could then fit easily into the baggage area.
I didn't fancy standing on my head to grab them off the float if
I needed them in a hurry .... worked ok.
If you don't have them already, you might want to keep an
eye out for a set of "SOS-PENDERS" - they are flotation vests that
look like fat suspenders, but inflate to give full floatation. They
run about $95 USD, but are so compact that you can actually WEAR them
when flying - making them really worthwhile. Several of the Rebel
driver here use them. You can get them at Sun 'n Fun & OSH, but I'm sure
they can be ordered from somebody directly .... will try to find
the manufacturers number.
------------------------------orig.-----------------------------------------
At 07:04 PM 8/20/01 -0700, you wrote:
murphy-rebel mailing list.
Margaret & Milton Thayer
Post by Margaret & Milton Thayer » Fri Feb 17, 2012 9:16 pm
Bob
One source for the SOS-penders is Cabela's.
The Web site www.cabelas.com
look under Marine, boat accessories, personal floatation.
Milt.
Bob Patterson wrote:
*-------------------------------------------------------------------------* The list archives are located at: http://www.dcsol.com:81/public/default.ht
m username: rebel password: builder*-------------------------------------------------------------------------*Hi Walter ! Yep ! Not all Canadian Tire stores have 'em, but they should,out your way. If not, a boat sh
op definitely will. The ends of thepump have a tapered fitting, so should fit the pump-outs easily.I bought a pair of the heavy plastic paddles that disasemble into2 parts because they could then fit easily into the baggage area.I didn't fanc
y standing on my head to grab them off the float ifI needed them in a hurry .... worked ok. If you don't have them already, you might want to keep aneye out for a set of "SOS-PENDERS" -
they are flotation vests thatlook like fat suspenders, but inflate to give full floatation. Theyrun about $95 USD, but are so compact that you can actually WEAR themwhen flying - making them really worthwhile. Several of the Rebeldriver here u
se them. You can get them at Sun 'n Fun & OSH, but I'm sure they can be ordered from somebody directly .... will try to findthe manufacturers number. ......bobp---------------------
---------orig.-----------------------------------------At 07:04 PM 8/20/01 -0700, you wrote:
m username: rebel password: builder*-------------------------------------------------------------------------*My floats are almost ready to take flight, so it is time to get a paddle anda pump for the pump-out holes. Any suggestions fo
r the pump? I noticed theseholes are smaller than the ones I've seen on other float planes. Is thissomething you can buy at a local Canadian Tire or boat shop?*-------------------------------------------------------------------------* You
have received this message because you have subscribed to the murphy-rebel mailing list. To unsubscribe from this list, send an e-mail to: list-server@dcsol.com with "unsubscribe murphy-rebel" in the body of the message. For assistance contact mike.davis@dcsol.com (mike.davis@dcsol.com)*-----------------------------------
*-------------------------------------------------------------------------* You have received this message because you have subscribed to the murphy-rebel mailing list. To unsubscribe from this list, send an e-mail t
o: list-server@dcsol.com (list-server@dcsol.com) with "unsubscribe murphy-rebel" in the body of the message. For assistance contact mike.davis@dcsol.com*-------------------------------------------------------------------------*
Thanks to you and Bob for these tips. Never heard of these SOSPENDERS before, but they definitely look worth looking into to. There are a lot of unique marine and outfitter shops around Vancouver. I wouldn't be surprised if I find them locally.
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Margaret & Milton Thayer
Sent: August 21, 2001 4:45 AM
Subject: Re: Pump for Murphy 1800 pump-outs
Bob
Milt.
---------orig.-----------------------------------------At 07:04 PM 8/20/01 -0700, you wrote:*-------------------------------------------------------------------------* You have received this message because you have subscribed to the murphy-rebel mailing list. To unsubscribe from this list, send an e-mail t
o: list-server@dcsol.com (list-server@dcsol.com) with "unsubscribe murphy-rebel" in the body of the message. For assistance contact mike.davis@dcsol.com (mike.davis@dcsol.com)*-------------------------------------------------------------------------*
Dave Qualley
Post by Dave Qualley » Fri Feb 17, 2012 9:16 pm
<!doctype html public "-//w3c//dtd html 4.0 transitional//en"> Hi Walter..
Mustang in Richmond makes the suspenders in a couple of different colours and models..
http://www.mustangsurvival.com/catalog/ ... &ColorID=4
I have a pair of them.. Very comfortable, you don't even know it's there..
SR#057
Walter Klatt wrote: [quote] Thanks to you and Bob for these tips. Never heard of these SOSPENDERS before, but they definitely look worth looking into to. There are a lot of unique marine and outfitter shops around Vancouver. I wouldn't be surprised if I find them locally. [quote] -----Original Message-----
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com (murphy-rebel@dcsol.com)]On Behalf Of Margaret & Milton Thayer
Bob
Milt.
Bob Patterson wrote: [quote] [quote]*-------------------------------------------------------------------------*
Rebflyer
Post by Rebflyer » Fri Feb 17, 2012 9:16 pm
Hi Walt,
I bought my pumpout from Lake and Air, the folks I got my pumpout cups from. I'm not sure of the size of the MAM pumpouts but I think they are the same. About 1 1/8" I think ( I'll try to remember to verify that) They also had rubber, cork shaped, plugs
that fit snuggly in the cup. I bought the shorter pump, that's 15" long, and about 15.00 us. It works well. Curt N97MR
Yes, I was at a Steveston Marina store today to buy my pump and saw the Mustang inflatable suspenders at $149 Cdn. They are Canadian Coast Guard approved, too, so don't have to worry about the marine cops nabbing me on the water with a US PFD. That actually happened to me, many years ago, on a windsurfer, if you can believe it.
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Dave Qualley
Sent: August 21, 2001 8:02 AM
Hi Walter..
SR#057
Bob
Milt.
Bob Patterson wrote: [quote][quote]*-------------------------------------------------------------------------*
Drew and Jan
Post by Drew and Jan » Fri Feb 17, 2012 9:16 pm
Mustang also makes a model that fits around your waist like a fanny pack. I
bought one for canoeing this spring and it is the only life jacket I have
ever worn in a boat when I wasn't already scared. I bought mine at a canoe
store in London ont. Canadian Tire sells the mustang suspender style.
Hi Walter.. Mustang in Richmond makes the suspenders in a couple of
different colours and models.. &ColorID=4 Very comfortable, you
SR#057
I ended up buying a Beckson model 212PC pump, about 12 inches long, very light, all plastic and can also be used to pump oil or diesel. I had to add a short plastic tube, similar to what the pump-outs use, to make it fit the tapered pump-out fitting. Cost was 24.59 CDN at Steveston Marine in Langley. They have a website, too, and sell to the U.S.
http://www.stevestonmarine.com/
From: murphy-rebel@dcsol.com [mailto:murphy-rebel@dcsol.com]On Behalf Of Walter Klatt
Sent: August 21, 2001 6:22 PM
Subject: RE: Pump for Murphy 1800 pump-outs
Hi Walter..
SR#057
Bob
Milt.
