In constructing the right wing, specifically, the main root rib, there is a
gap between the angle plate covering the stringer cut-out (under the root
rib flange) and the tank skins, caused by the root rib flange being
'sandwiched' between the two. I was wondering if anyone is filling that gap
with anything, other than the pro-seal. The manual doesn't mention anything
about it, but I was thinking of cutting some small .030 thick spacers with a
single #30 rivet hole to place between the tank skin and the angle plate to
fill that gap.
Or, will the rivet just force the two together with pro-seal filling any
remaining gap?
Thanks for any advice,
R. Hoffman #687R
Eugene, OR USA
Wing stringer cut-out
Terry Dazey
Roger:In constructing the right wing, specifically, the main root rib, there is a
with anything
You and myself are pretty close in the construction. About 15 minutes ago, I just
got through making some small aluminum rectangle shims exactly like you mentioned.
Since there is no mention of this in the instructions, I am ASSuming that there
would be a bit of an indent if nothing was there to bridge the gap. Goop with
proseal and rivet in place with the tank skin.
Terry Dazey
Rebel 662
roger
Terry,
Thanks for your advice. It's great to have others to talk with who have
"been there, done that".
R Hoffman #687R
Eugene, OR USA
R Hoffman #687R
Eugene, OR USA
Terry Dazey
Rebel 662
C&P Kucera
Hi Roger.
I formed (banged) a little step in the angle using two 40 thou steel plates
(spaced apart the right amount) as a die and a makeshift square punch.
Worked out great.
I would not bother with spacers, Proseal will easily fill the gap.
Paul Kucera
Rebel 453
From: "Roger and Alice Hoffman" <rognal@continet.com>
Sent: Saturday, March 10, 2001 6:51 PM
Subject: Wing stringer cut-out
Worked out great.
Paul Kucera
Rebel 453
gapgap between the angle plate covering the stringer cut-out (under the root
anythingwith anything, other than the pro-seal. The manual doesn't mention
aabout it, but I was thinking of cutting some small .030 thick spacers with
tosingle #30 rivet hole to place between the tank skin and the angle plate
*---------------------------------------------------------------------------fill that gap.
remaining gap?
R. Hoffman #687R
Eugene, OR USA
*---------------------------------------------------------------------------You have received this message because you have subscribed to the
murphy-rebel mailing list.
klehman
Roger
You may not want to make things too complicated. It will be an annoyance
to fit extra spacers in while applying pro-seal. I can't really envision
why you'd need them anyway. The only gap I remember was an extremely
small (maybe 0.010") gap between the stringer and the angle plate caused
by the 0.032 wing rib flange being slightly thicker than the stringer
material. Perfect situation for sealing with pro-seal.
I left the stringer against the tank skin and then added the angle plate
last. The flange on my angle plates were only about a half inch wide,
similar to the flange on the rib. I'm sure there is more than one way to
do this but I found that the fewer pieces the better when the pro-seal
was sticking to me fingers.
fill that gap.
remaining gap?
R. Hoffman #687R
Eugene, OR USA
Paul,
Thanks for this tip. I'm going to give it a try this weekend.
Roger #687R
Eugene, OR USA
Roger #687R
Eugene, OR USA
Worked out great.
Paul Kucera
