Hi to all,
I had intended on using a WD but have now been considering a wood Sensenich
because of the delamination problems. If I go this rout I might have a Mark
Landoll vibration dampener to sell. The wood Sensenich will Weigh less than
half a WD and dampener. I have not cut back the firewall so weight is my main
concern. Any one have experience with the wood blades? Other than not lasting
as long, do they perform the same as a metal Sensenich?
Bruce G
Wood prop
Wood prop
Bruce,
Not likely to work as well as the Sensenich, as I believe the secret as to
why the DM74 x 56 (or 52 on floats) works so well, is the fact that it
weighs 40 pounds. Once you get it up to speed, it is a huge flywheel with
lots of momentum to help pull the thing along. It also has VERY wide chorded
blade tips, in comparison to any McCauley or wooden propellor that I have
seen, giving a better bit in the air out were it counts (away from the nose
bowl).
Blue skies,
Sent: Friday, March 02, 2001 7:46 PM
Subject: Re: Wood prop
bowl).
Blue skies,
SensenichHi to all,
Markbecause of the delamination problems. If I go this rout I might have a
thanLandoll vibration dampener to sell. The wood Sensenich will Weigh less
mainhalf a WD and dampener. I have not cut back the firewall so weight is my
lastingconcern. Any one have experience with the wood blades? Other than not
*---------------------------------------------------------------------------as long, do they perform the same as a metal Sensenich?
Bruce G
*---------------------------------------------------------------------------You have received this message because you have subscribed to the
murphy-rebel mailing list.
Legeorgen
Wood prop
Wayne,
So the wood Sensenich is a different shape than the metal Sensenich? For a
wood prop Sensenich recommended a W74EM 56. Do you think I would be better
off with the metal prop and extra weight, even if it made the plane nose
heavy?
Bruce G
heavy?
Bruce G
Wood prop
Bruce, the Sensenich "DM" propellor I am talking about, has a wider blade
chord than any other Metal Sensenich prop I have seen either. If the wood
propellor Sensenich is suggesting has the same blade profile as the DM, it
might work almost as well. Although of course they don't last long when you
get caught flying in heavy rain, or as Bob has spelled out if you don't
hanger your plane.
Regards,
Sent: Saturday, March 03, 2001 11:50 AM
hanger your plane.
Regards,
*---------------------------------------------------------------------------Wayne,
heavy?
Bruce G
Rebflyer
Wood prop
Hi Bruce,
If you decide to sell the dampner, I'm interested.
I already own the prop, and I plan on installing it this next month. I had convinced myself to now go with the dampner, so let me know, I'll have to order one.
Thanks for your consideration. Curt N97MR
Legeorgen
Wood prop
Curt,
I think I'll go with the WD prop but haven't made up my mind on the dampener.
You might just go ahead and buy one if you're that close to needing one. I
may change my mind.
Bruce G
may change my mind.
Bruce G
Rebflyer
Wood prop
Hi all,
Maybe the group discount would help! I could order them to my place and
then bring them to a builders meeting. When the weather gets nice, I
believe that's every weekend!
Really though, if that call is made, and a group count is needed, count
me in.
Bruce, thanks for the reply, I'll go from there.
Just an aside, I'm putting the bottom skins on the second float now. got
the back half done last night.
someone asked about a reason not to close the back up as per the
instructions, I really can't think of a good reason, other than just look
ahead to make sure your not causing yourself extra work, like running lines
etc. after the close
Curt N97MR Keep at it, it's worth it
me in.
