[rebel-builders] Windows
Post by Wayne G. O'Shea » Sun Feb 19, 2012 8:50 pm
The bushings would defeat the purpose of oversizing the lexan holes IMHO. I
drill everything at #30.. and then open the lexan holes up 2 fraction sizes
bigger than 1/8ths in my drill box. My brain's toast these days.. but I
think that one's 5/32. Pull rivets with the least amount of air pressure
possible and slowly.
To: "MAM email list" <rebel-builders@dcsol.com>
Sent: Thursday, April 28, 2011 1:17 PM
Subject: [rebel-builders] Windows
Hi all, question on the windows ( side windows not the windshield ), I'm
riveting the acrylic between two pc of aluminum and have been told to
oversize the hole in the acrylic and put bushing's in each hole then
rivet.
I understand the oversize holes, however I think the bushing's are
overkill.
Does somebody want to give me some advice?
Greatly appreciated.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
Post by Bob Patterson » Sun Feb 19, 2012 8:50 pm
Hi Kelly !
You really should be using the Murphy window frames !
The Lexan just floats in these frames, with NO holes, just
sealant.
Also, the windows should be LEXAN - if you use plexi, you
definitely need bushings to avoid too much pressure.
Even drilling the holes will be a challenge ...
bobp@prosumers.ca
bobp@pattersys.com
http://www.Pattersys.com
De-fenestrate now ! Linux is the answer !
responsibility of the reader.
http://www.danasoft.com/sig/pssignTux.jpg
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
Kelly M. Ewing
Post by Kelly M. Ewing » Sun Feb 19, 2012 8:50 pm
Thanks Wayne, I'm thinking along the same lines.
Kelly
kelly@tru-form.ca
Enjoy your day !
Sender: <mike.davis@dcsol.com>
Date: Thu, 28 Apr 2011 13:29:19
Subject: Re: [rebel-builders] Windows
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
I also missed you stating Acrylic... I wouldn't even consider same for all
the side windows and skylights. Cracks way too easy, both working with it
and over time from vibration. Lexan gets scolded for the inability to break
it in a crash senerio to get out through a window.. but the Murphy doors
aren't that strong anyhow that you wouldn't have that kicked open before a
side window pane anyhow.
Sent: Thursday, April 28, 2011 1:36 PM
Kelly
kelly@tru-form.ca
Enjoy your day !
sizes
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
Kelly M. Ewing
Hi guys sorry for the confusion. I'm working on the bubble windows. ( Pilot and Co- Pilot)
So I'm confused, in the MAM instructions it says "Acrylic" and the bubble windows I have from MAM. I would assume are acrylic.
I called LP Aero and they told me to use the bushing's ?
Side note: is plexiglass not a brand name for Acrylic ?
Kelly
kelly@tru-form.ca
Enjoy your day !
Date: Thu, 28 Apr 2011 13:41:58
Kelly
kelly@tru-form.ca
Enjoy your day !
sizes
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
Well I guess you have no choice on the material then. FWIW.. my LP Aero
Rebel windshield is drilled and bolted THRU the windshield in at least 100
places, as per MAM's original install instructions. It's been in place for
15 years now... on floats for 5 summers without issue. Holes just drilled
oversize and no bushings.
Of course now that I've said that I'm glad I have a spare here in a box....
;O)
Sent: Thursday, April 28, 2011 2:21 PM
Kelly
kelly@tru-form.ca
Enjoy your day !
break
Kelly
kelly@tru-form.ca
Enjoy your day !
sizes
I'm
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 8:50 pm
Hi Bob
In order to let the side windows float what sealant does MAM suggest?
Charlie E. 802R
Sent: Thursday, April 28, 2011 12:30 PM
Hi Kelly !
sealant.
bobp@prosumers.ca
bobp@pattersys.com
persons.
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
Hi Charlie !
You will hear LOTS of suggestions !! :-)
The windshield manufacturer strongly recommends
Bostick 1100 - they even sell it. You can get it at most
hardware or lumber stores, in caulking gun cartridges,
in several colours - I like gray ...
Have used it on several Rebels for windshields,
skylights, and side windows - stays flexible, even in winter.
Wayne - the EARLY LP Rebel windshields WERE Lexan !!
They switched later to Plexi ... much easier for them to
form. Now easier to install, without the holes ! ;-)
Can't remember the setup for the bubble windows -
thought the swing-up windows had a doubler to hold the
Plexi without drilling it .... been a long while ...
You definitely want the opening side window kit !! ;-)
bobp@prosumers.ca
bobp@pattersys.com
http://www.PattersonAeroSales.com
On April 28, 2011 04:58:25 pm Charlie Eubanks wrote:
Hi Bob
Charlie E. 802R
Hi Kelly !
sealant.
bobp@prosumers.ca
bobp@pattersys.com
persons.
the responsibility of the reader.
I'm riveting the acrylic between two pc of aluminum and have been told
to oversize the hole in the acrylic and put bushing's in each hole then
rivet.
overkill.
Kelly ( Moose )
kelly@tru-form.ca
Enjoy your day !
I find it hard to believe that LP Aero used a "foreign" material to form
windshields (vs every other one they make), instead of using their standard
cast cell acrylic sheet. I really can't see them using Lexan Bob... and I
know my very first windshield circa 1993 was acrylic. The only change I know
of from the original moulded windshield, that Robin could tell you what
speed it popped back out at to the current one, was the addition of more of
a hump in the center to stop the in/out pop.
The only original Rebel windshield that was Lexan, TTBOMK, was the center
post and wrapped sheet windshield for the earlier kits, pre moulded
windshield availability. When the moulded ones came out, MAM's supplied
install kit gave you the deraked drill bits for drilling the acrylic, a big
bag of bolts/nuts and instructions on how to drill and bolt in place.
Sent: Thursday, April 28, 2011 6:19 PM
Hi Charlie !
bobp@prosumers.ca
bobp@pattersys.com
persons.
Hi Bob
Charlie E. 802R
Hi Kelly !
sealant.
bobp@prosumers.ca
bobp@pattersys.com
persons.
Ken Lehman
Post by Ken Lehman » Sun Feb 19, 2012 8:50 pm
Agree that bushings are likely overkill. This plastic expands about 3
times more than aluminum so oversize holes are good. I also like to use
aluminum rivets with ALUMINUM mandrels that do not expand (non avex) as
they don't pull very hard before breaking off.
Hi Charlie !
bobp@prosumers.ca
bobp@pattersys.com
persons.
totally the
Hi Bob
Charlie E. 802R
Hi Kelly !
sealant.
bobp@prosumers.ca
bobp@pattersys.com
sender
persons.
told
hole then
BBS 42/Albedo Webmail
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 8:50 pm
The bushings are likely to prevent the fastener from gripping too tight
and then you won't have to worry about pulling the rivet gently. I would
make the hole in the acrylic/lexan oversized for the bushing as well.
Bob.
Hi Charlie !
bobp@prosumers.ca
bobp@pattersys.com
persons.
totally the
Hi Bob
Charlie E. 802R
To:<rebel-builders@dcsol.com>
sender
told
hole then
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 8:50 pm
As much as I like Lexan for durability it is softer and scratches easily.
Just the act of cleaning it to remove the daily layer of dust will probably
lead to a early permanent Halo which is not too desirable when facing into
the sun.
Just my 2 cent comment!
Dick Wampach SR-108 N331RW
Palmer
Sent: Thursday, April 28, 2011 5:10 PM
Bob.
use aluminum rivets with ALUMINUM mandrels that do not expand (non
avex) as they don't pull very hard before breaking off. Ken
Hi Charlie !
Bostick 1100 - they even sell it. You can get it at most hardware or
lumber stores, in caulking gun cartridges, in several colours - I
like gray ...
Have used it on several Rebels for windshields, skylights, and
Can't remember the setup for the bubble windows - thought the
bobp@prosumers.ca
bobp@pattersys.com
persons.
totally the
Hi Bob
suggest? Charlie E. 802R
sender
told
hole then
password "builder"
