[rebel-builders] Rebel Gas Cap
I have a pair of them with their bases. Mike. Rebel #482
Sent wirelessly from my BlackBerry device on the Bell network.
Envoy
Envoy
Hi Andrew: Sorry to hear that you lost the gas cap; that tends to be an
emergendy situation because you can't fly without it. I would get at least
two new ones and take a spare one on board, or there is a method to chain
them to the tank without making any holes, obviously. I have a Moose and got
mine at Aircraft Spruce, even with two keys to lock them. Regards, Eduardo
El 20/12/10 12:55, "Andrew Burr" <verticalperformance@yahoo.com> escribi
FYI - This will be obvious to many but... a gas cap retainer photo is at:
http://n254mr.com/node/982 I got the stainless shash chain at
http://www.kilianhardware.com, the ~90 deg. springs at a local hardware
store, and bent ~5/8" of each spring leg outward to grip the inside of the
filler neck. IMHO, the retainer is mostly to keep the cap from rolling off
the wing during fueling and mangling the snorkel vent. I also carry a spare
cap w/snorkel vent.
Ron
On Mon, Dec 20, 2010 at 11:49 AM, Eduardo Gutierrez Sosa <
lopeco.eduardo@gmail.com> wrote:
cap w/snorkel vent.
Ron
......., or there is a method to chain
Just never take the chain for granted.. that's how most of them get lost.
Pop the cap.. drop it on the wing and DANG.. the chain is broke!
I take mine off, to fill the tank, and put it in my pocket.
Sent: Monday, December 20, 2010 4:11 PM
Subject: Re: [rebel-builders] Rebel Gas Cap
spare
cap w/snorkel vent.
Ron
Back to Anrew's original question, I'm wondering if you can get replacement caps anywhere? There are some in the ACS catalog that look similar, but not sure.
Date: Mon, 20 Dec 2010 16:32:10 -0500
spare
cap w/snorkel vent.
Ron
Acs has a Piper vented cap and 180 HP cap that has a snorkel on it that both look similar to the MAM style.
Subject: RE: [rebel-builders] Rebel Gas Cap
Date: Tue, 21 Dec 2010 07:59:27 -0800
spare
cap w/snorkel vent.
Ron
When I wanted to get a couple caps for spares, the only ones I could find
that would fit were from MAM. Whether MAM still has any to sell at this
point -- don't know. Sure would be nice to confirm another source.
Ron
N254MR
Ron
N254MR
Have you tried Wag Aero?
They have a simular one for about $40.00
Ram Air Pressure Cap
Wag-Aero
SKU: E-481-000
$37.95
http://store.wagaero.com/index.php?cPath=601_151
On 12/21/2010 9:48 AM, rshannon@cruzcom.com wrote to rebel-builders:
-> When I wanted to get a couple caps for spares, the only ones I could find
-> that would fit were from MAM. Whether MAM still has any to sell at this
-> point -- don't know. Sure would be nice to confirm another source.
-> Ron
-> N254MR
Wag-Aero
SKU: E-481-000
$37.95
-> Ron
-> N254MR
I haven't tried that one, but I did try their "Piper" cap (SKU:
E-482-000<http://store.wagaero.com/product_info.p ... ts_id=1916>
on
the same web page) and it didn't fit.
Ron
on
Ron
Wag-Aero
SKU: E-481-000
$37.95
Oh man, don't leave your planes out of sight guys...Rebel fuel caps are going to become a hot commodity. I knew I should have riveted my filler neck flanges to the outside of the tank skins. Now when I lose a fuel cap I'm going to have to open the tank just to put on a different filler neck/cap combo. That's what vanity will get you.
Seriously though, there must be a replacement out there somewhere. If not from mam then hopefully they would divulge the supplier. It looks like a generic part...probably not aviation.
Date: Tue, 21 Dec 2010 11:50:13 -0800
on
Ron
Wag-Aero
SKU: E-481-000
$37.95
Hello All
Don't know if this will satisfy your needs. I purchased a pair of Fuel caps
from ACS at Oshkosh 2010. I did not like the caps Murphy furnished with my
Rebel kit. For one they were perfectly round and I like the lobes for
leverage for the thump and middle finger I also want to install
Charlie, do these caps from ACS fit on the Murphy filler necks? They look like they are threaded. My caps are the cam style (about 1/2 turn) with no threads.
[quote]From: charlie@troyairpark.com
Date: Tue, 21 Dec 2010 17:59:12 -0600
Hello All
Hello All
Jesse, I believe 05-01060 screws into 05-02711. The caps (05-01057 & 58)
themselves grab the cam lobes you see on 05-01060.
If these fit the stock Rebel neck, they'll soon be out of stock. :)
Ron
Ron
threads.
capsFrom: charlie@troyairpark.com
Hello All
Don't know if this will satisfy your needs. I purchased a pair of Fuelmyfrom ACS at Oshkosh 2010. I did not like the caps Murphy furnished withreplaceRebel kit. For one they were perfectly round and I like the lobes for
leverage for the thump and middle finger I also want to install ź Dia.
Polarized periscopes on each tank cap. They came with a 1/8 rubber gasket
which is a little too thick. I plan to weld in a S.S. periscope andUn-ventedthe 1/8 gasket with one about 1/16 or 3/32 thick. ACS # 05-01057$8.80 each. Page 157.
Hopes this helps.
Charlie E. 802R
I would like to sell a pair of Murphy gas caps & bases. I do not need them. Also for sale a new Whelen comet flash A413A-HDA-CF-14/28, 2-A600-PG/PR wingtip nav strobe,installation kit $700.00
Envoy
Envoy
Jesse,Ron
Yes they fit on the Murphy filler necks I received with my kit. They only
equire about 1/4 turn clockwise from insertion to the lock prosition.. They
are not threaded. Filler cap is 1.54 ID x 2.3 OD.
Charlie
To: "Builders list" <rebel-builders@dcsol.com>
Sent: Tuesday, December 21, 2010 7:30 PM
[quote]
threads.
Hello All
caps
my
Charlie
[quote]
threads.
Hello All
caps
my
