actually get overcenter. With a shorter stop bolt I have a little over
center but it is not a lot. Maybe 3/16". I could have adjusted for a bit
more but then the gear would not retract quite as far.
Garry Wright wrote:
Is there a measure of how much over center the main gear should be when
fully down? I had one collapse yesterday in the hangar and increased it
about 3/16" on the threads of the stop bolt and it seems to work but
there must be a design parameter here which I don't have. This is after
a bit of re-work on the float in question. New bolts, mount brackets.
Garry
FOKM
