I suggest that folks buy the fuel shutoff valves for the
Renegade, or something equally cheap & simple, and install them
at the <bottom> of the sight tubes. This gives you a simple shutoff
if you need to replace the guage tubing, without draining the tank,
OR - if you see trees coming !!! ;-)
....bobp
-----------------------------orig.------------------------------------
At 06:58 PM 11/26/00 +0400, you wrote:
---------*Post crash fuel feed fires have always concerned me. As such I've gone
to Westac sending units. Also for belt and braces I installed the MAM
site fittings, however will cap off..When I flew in the military we had
crash proof fittings that self sealed when displaced. Does anyone know
where they can be had? I'll be doing a lot of bush flying and as was
previously stated "aim between the trees". I'd at least like some
protection against a leak if the wings are folded back.
Warren T. Montgomery
<monty@emirates.net.ae>
Dubai, United Arab Emirates
