want the extra weight of two sets of attach
fittings but never thought the extra set could be
used as a multi purpose attach point. Yes indeed,
more think time. Thanks for the ideas all.
Curt Brockway E695
Bob Andrews wrote:
mightThanks Wayne for reminding me where I "picked it up" from. For me anyway
... the jury's out on this one ... thanks for everyones participation and
inputs.
Bob e612
Sent: Thursday, March 10, 2005 7:34 PM
Subject: Re: rear float brackets
As I already posted it's true Bob..if you give it the boot and haul the
stick back immediately you put the MAM 1800 rear spreader under water. Also
when doing plow turns... as if you don't have the spreader sealed off to the
float skins you fill the compartment where the spreader stubs come out of
the floats to bolt the speader bar to.
Sent: Thursday, March 10, 2005 9:16 PM
Subject: RE: rear float brackets
niceFound this Elite 1800 Amphib MAM installation on the NW Rebel site ...http://groups.msn.com/NWRebelExperiment ... intallatiopaint job. Those aft struts look pretty vertical ... and long.
thenn.msnw
Think the bottom line on all this is ... if you have an aft spreader bar
location like the MAM 1800's (or the two special 2200's that MFC built)withthe MAM aft fitting is the one to use. If you have regular MFC 2200's
(which has the aft spreader bar more forward then the 1800's) ... then the
MAM aft fitting can be used too ... or to get the strut more vertical,
attaching one station forward to the aft door post location is the way to
go. From what I've picked up thus far, the advantage to the more forward
aft spreader bar MFC 2200's is that the spreader bar won't make contactwater,the water during take offs. However, I haven't flown either off theareso I can't speak from experience ... only what I've picked up. If thereMAMany out there reading this, would like to hear from Elite (or Rebel if
applicable) amphib drivers with experience taking off the water with thethe1800's set up ... specifically the aft spreader bar in the water issue (to
dispell or validate) ... thanks.
Bob e612
Alan Hepburn
Sent: Thursday, March 10, 2005 6:04 PM
Agree - they're not Montanas. The nose gears are different, the rear
spreader is too far back (though that could be one of these two sets), you
can see the tops of those circular plastic access hatches, and it's not
Keith's rigging.
Al
Sent: Thursday, March 10, 2005 5:01 PM
theHi Mike ... I thought so too at first, but then I saw what looked like
[lightening like] holes in the nose gear forks which looked the same as1800's ... and I couldn't tell if the nose gear legs were flat or round.
Also the MFC 2200A's I had seen before had black spackled paint aft ofsetasgreen paint, and these don't ... but it could have been an early picture2200's.you mentioned. Indeed you may be right on here ... they may be MFCtheI just learned that Keith made two special sets of 2200A's targeted forinElite/Rebel that had the aft spreader bar at the same station as the MAM
1800's (aft of the normal MFC 2200A's) ... so that throws a slight curvethemy picture based analysis as I can't be sure which model MFC 2200 is onbothG/W Elite. Did have fun moving the pixels though ... and putting themgoodin a power point slide show and with a camera click sound transitioning
between the two pictures made for some pretty cool dynamic aft struts.
Bob e612
Sent: Thursday, March 10, 2005 2:11 PM
Hi Bob, that photo is of the old factory demonstrator... if I'm not
mistaken, those are Montana 2200 floats on there.
195SR
Sent: Thursday, March 10, 2005 5:39 AM
knows,fish...side.oftheforandrivetedthesurgerytobad,stickaswaywasnotattachpoints,attachoutside.ago,the
holewiththe life!
outside!ares
shouldIs
https://www.dcsol.com/login?mode=HTMLalsointendedbehttps://www.dcsol.com/login?mode=HTML-----------------------------------------------------------------https://www.dcsol.com/login?mode=HTML ----------------------------------------------------------------- ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
[/quote]
