Deburring
John Kramer
deburring
Post by John Kramer » Sat Feb 18, 2012 1:05 pm
I've been using a scotchbrite wheel on a drill which seems to smooth the
holes fast and easy. Is this a bad idea?
John...
At 12:20 PM 01/26/05, you wrote:
be careful using this deburing tool that is spring loaded and does both
sides of material
yes it works great when it works but as it is used and gets dirty or
slightly bent it jams an then cuts a hole to big for a 1/8 rivet, i had this
happen and had to use alot of 5/32 rivets on some parts, but when it work
good it was great just watch it very closely or you have problems and you
may not notice till you go to rivet
can be purchased at aircraft tool supply company for 79.95, here is link to
page, called two-way deburring toll #td001
http://www.aircraft-tool.com/shop/searc ... x?PageNo=3
mike#007
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]On Behalf Of Al
Paxhia
Sent: Wednesday, January 26, 2005 1:13 PM
Subject: Re: deburring
I did top and bottom holes and would recommend it. There is a slick deburing
tool that has a spring loaded cutter, debur the top, push it through and
debur the bottom. Ill dig around and find the source (I got mine from Boeing
Surplus several years ago).
Al
Moose, N526AP
Sent: Wednesday, January 26, 2005 5:52 AM
Subject: deburring
I don't want to sound stupid but I would like to clarify something on
deburing skins. I'm on the stab and figure I can pass on what I learn here
to the rest of the project. After drilling the stab skin to final size I'm
getting ready to debur. The 5/16 drill bit by hand works great and is fast
for the bottom of the hole. My question is the top of the skin, it seems
the holes are pretty clean already. I can rub my finger over them and
don't really notice any raised edges. I'm using a pretty fast air drill.
Do I still need to put a little chamfer on them too? Is the group here
still running a bit over all those clean holes on the skins or is this
probably acceptable.
Mike Betti
771E
Fly too low or too slow and the ground will rise up and smite thee.
deburring
Post by Drew Dalgleish » Sat Feb 18, 2012 1:05 pm
I hope not thats how I did a lot of the holes on my floats. Preps them for
the sikaflex at the same time.
John...
deburring
Post by Bob Patterson » Sat Feb 18, 2012 1:05 pm
Hi John !
Definitely the fastest way to deburr - but best only on inside surfaces,
as the scuff marks will show on the outside, even through paint.
John...
sides of material
this happen and had to use alot of 5/32 rivets on some parts, but when it
work good it was great just watch it very closely or you have problems
and you may not notice till you go to rivet
to page, called two-way deburring toll #td001
mike#007
Paxhia
deburing
Boeing
Al
Moose, N526AP
Subject: deburring
here
I'm
fast
seems the holes are pretty clean already. I can rub my finger over them
and don't really notice any raised edges. I'm using a pretty fast air
drill. Do I still need to put a little chamfer on them too? Is the
group here still running a bit over all those clean holes on the skins
or is this probably acceptable.
Mike Betti
771E
Bobby Sather
deburring
Post by Bobby Sather » Sat Feb 18, 2012 1:05 pm
Bob, Off the subject, but do you know Bill Kingston?
Thank You
Bobby Sather
Sent: Wednesday, January 26, 2005 12:38 PM
Hi John !
surfaces,
John...
both
sides of material
had
when it
problems
link
mike#007
Al
Paxhia
deburing
Boeing
Al
Moose, N526AP
Subject: deburring
on
learn
here
size
I'm
is
fast
them
air
skins
Mike Betti
771E
recipient
disseminate,
Jones, Michael
deburring
Post by Jones, Michael » Sat Feb 18, 2012 1:05 pm
sides of material
mike#007
Paxhia
Al
Moose, N526AP
Subject: deburring
Mike Betti
771E
pollock
deburring
Post by pollock » Sat Feb 18, 2012 1:05 pm
If you looked with a magnifying glass on the holes that are not debured
,there would be multiple fracture on the lip.Proper deburring cleans away
stress point preventing cracks and allowing the surface to mate tight.
Bill
Moose 244
Sent: Wednesday, January 26, 2005 1:29 PM
I would also add that for skins I use a dowel handle and turn the tool by
hand. On thicker material a battery powered screwdriver works well, but be
careful.
Al
Sent: Wednesday, January 26, 2005 10:20 AM
Subject: RE: deburring
sides of material
this
mike#007
Paxhia
deburing
Boeing
Al
Moose, N526AP
Subject: deburring
here
I'm
fast
Mike Betti
771E
mbetti
deburring
Post by mbetti » Sat Feb 18, 2012 1:05 pm
I don't want to sound stupid but I would like to clarify something on deburing skins. I'm on the stab and figure I can pass on what I learn here to the rest of the project. After drilling the stab skin to final size I'm getting ready to debur. The 5/16 drill bit by hand works great and is fast for the bottom of the hole. My question is the top of the skin, it seems the holes are pretty clean already. I can rub my finger over them and don't really notice any raised edges. I'm using a pretty fast air drill. Do I still need to put a little chamfer on them too? Is the group here still running a bit over all those clean holes on the skins or is this probably acceptable.
Mike Betti
771E
Al Paxhia
deburring
Post by Al Paxhia » Sat Feb 18, 2012 1:05 pm
Al
Moose, N526AP
Subject: deburring
Mike Betti
771E
Jean Poirier
deburring
Post by Jean Poirier » Sat Feb 18, 2012 1:05 pm
Hello to all!
I am using "Scothbrite type) from Sait for all the deburrring. I use the
blue one , in Sait that mean "fine". I use them on a mini angle die
grinder. You have to be carefull and use it at a slow speed. Skin are
have a very "souft touch " after. But...... A friend of mine who is also
an "inspector" (not mine) show somw reserve.... He asked me if the very
small cracks are removed with that process .... As far as I see everything
look ok! I have use a magnifier and it is look ok. I plan to doublr
check with a microscope to be sure. I do not think that some "bevel" that
are made with drills are much better but I am not an expert. For sure I
will push the research further I am will post the results
If you use fine type, after primer no marks stay there ...
Jean
Rebel 747R
Sent: Wednesday, January 26, 2005 2:38 PM
Hi John !
John...
sides of material
it
link
mike#007
Paxhia
deburing
Boeing
Al
Moose, N526AP
Subject: deburring
bransom
deburring
Post by bransom » Sat Feb 18, 2012 1:05 pm
I can't figure using scotchbrite for deburring -- I thought that was just for
scuffing and cleaning surfaces. At risk of piling on, I'll pile on with
those recommending the single flute bits for deburring holes. It is very
easy to do, very easy to not over-do, and especially with the plastic coating
still on surfaces you can even be somewhat reckless in quickly popping hole
after hole, after hole, after hole afterholeaftherholeafterhole......
-Ben
Hello to all!
everything
Jean
Rebel 747R
Hi John !
John...
At 12:20 PM 01/26/05, you wrote: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
deburring
Post by Ralph Baker » Sat Feb 18, 2012 1:05 pm
Mike, you do not want to champfer at all. drryl has been quoted that
the most common builders mistake is "over deburring". If it is smooth
thats it. If you want to, a fine cut flat file over the surface will
make sure.
deburring
Post by Ralph Baker » Sat Feb 18, 2012 1:58 pm
Terry,
Boeing surplus (near you!) has the two way deburring tools occasionally
in their surplus store at 25 cents each. Beats the about $50 ACS wants.
Well used but generally serviceable ones can be found with a little
looking. Might be worth your time brokering them when it's not out of
your way. They do work well. On th other hand they make poor back
scratchers, unlike Wayne's suggestion.
Terry Dazey
deburring
Post by Terry Dazey » Sat Feb 18, 2012 1:58 pm
Hello Ralph:
I was at Boeing Surplus recently and the pickens ain't what it used to be
compared to ten years ago. The past years, Boeing has been outsourcing more
and more projects to overseas companies which makes the pick of the
"surplus/ used" tools and parts pretty thin now. Consequently, used tools
are not as plentiful as they were. You need to be "Jonny-on-the-spot" to get
the good ones as they are offered to the public. The good ones get picked
over pretty quick as you can imagine.
Also, years ago Boeing stopped selling AN hardware because of the liability
issues. Consequently, no AN bolts, nuts, washers etc. for sale. You can
still get aluminum, bar stock and material similar stuff. There again, luck
is on your side if you find something you are looking for. If you can find
what you are looking for, typically prices are very good! If you are a
Boeing employee or retired employee, they give an extra discount at the cash
register.
As far as the back scratcher . . . I suppose I could stop by there and
scrounge and old 737 throttle interlock mechanism and make my own . . .
cheap.
Terry Dazey
Rebel 662
Bonney Lake, Washington USA
Deburring
Post by Mike Davis » Sun Feb 19, 2012 11:35 pm
To: mike.davis@dcsol.com
Sent: Thursday, January 20, 2011 11:18 AM
Subject: Deburring
You also can use a cordless screwdriver eg. Millwaukee,on low speed with a deburring bit mounted on screwdriver bit shaft. Very ease to control & not tiring.Clevland Tool Supply has this great bit.
