Just installed the first one.
Ryan Mowat, P.Eng.
30528 1A Greatnorthern Ave
Abbotsford, BC V2T 6H4
(604) 556-7222 (ext 307), (604) 556-7215 (Fax)
Sent: Wednesday, March 09, 2005 11:50 AM
Subject: Re: Landing lights
Murphy has kits for both the leading edge and the tip lights. I'm told,
unfortunately, that the droop tip lights are considerably more expensive
than the old style standard tip light kit. This is mainly due to the mfg
having to produce new tooling for the considerably different lens. The
leading edge double light kits are now manufactured in house at MAM.
Trevor
Y. used to put them together for MAM, but due to his job requirements
etc he
has had to stop production. The only difference between the kit Trevor
was
making and MAM's is the lens. MAM says they would have had to
significantly
increase the price of the kit in order to cover their cost to have the
lens
manufactured for them. Instead they have gone to a slightly lighter
gauge of
lexan and the lens is now just wrapped around the leading edge. It's
definitely acceptable and in the long run replacement in the field no
longer
requires ordering a manufactured part from MAM, just head down to the
nearest plastic shop / Home Depot and pick up a square foot of Lexan.
Of course there is nothing stopping anyone from making their own tip
lights.
I've done plenty of them using both rectangular and round halogen
lights.
Sent: Wednesday, March 09, 2005 7:38 AM
Subject: RE: Landing lights
bentmike
man landing light kits are great, made by fellow not far from me in
burlington ontatio, will save you many house of work, comes with lexan
withto shape as well
mike#007
Mike Betti
Sent: Tuesday, March 08, 2005 9:11 PM
Subject: Landing lights
I see some of the group out there is using the wing mounted landing
lights from MAM. Are these light kits the way to go? Are you happy
the results? Also which wing bay are you putting them in. I plan on
doing both wings.
Mike Betti
771E
