Which o 320 is in your Rebel?
Post by Drew Dalgleish » Sat Feb 18, 2012 4:43 pm
IIRC the lycoming starter weighed in at 26lbs and the toyota starter with
bracket that I'm using weighs 8lbs
At 05:14 PM 9/28/2005 -0800, you wrote:
I wonder if anyone has put together a comparison of how much you actually
save with different options. FOr example, lightweight starter over a
standard starter, save 4 lbs, Prince prop over the Sensenig prop, 25 lbs,
etc??
-> X-Sender: drewjan@mail.cabletv.on.ca
-> X-Mailer: Windows Eudora Light Version 3.0.1 (32)
-> Date: Wed, 28 Sep 2005 17:17:56 -0400
-> From: Drew Dalgleish <drewjan@cabletv.on.ca>
-> Subject: Re: Which o 320 is in your Rebel?
-> In-Reply-To: <1127876982@dcsol.com>
-> >Also, what all can I do to lighten the load out front?
-> Lightweight starter, nippondenso alternator, and a composite prop are the
-> biggies. You can also save weight on your exhaust, electronic ignotion
-> instead of mags and use an aluminum cowl.
-> Drew
Rick Harper
Post by Rick Harper » Sat Feb 18, 2012 4:43 pm
G'day from OZ
We have an IO-320 B1A .... wooden prop, B&C lightweight starter &
REAR mounted "SD 20" alternator - driven off the vacuume pad, electronic
ignition .... saved 40 - 50 Lbs we reckon !
Rick
541R
PS gel cell battery on the engine side of the firewall & 10Kgs lead shot
in the tailcone - Flys GREAT
Sent: Wednesday, September 28, 2005 1:09 PM
Subject: Which o 320 is in your Rebel?
I have talked to Bob a couple of times about the engine that is in the
REbel
that I am buying.
This one is a 0-320-E2A. I am wondering what most of you guys have
put in
yours?
Post by Ken » Sat Feb 18, 2012 4:43 pm
8 lbs for the Toy starter is probably correct as that is what my geared
Soob starter weighs and they look very similar.
Bruce Uvanni
Post by Bruce Uvanni » Sat Feb 18, 2012 4:43 pm
What Toyota starter are you using, Do you have a year and make to cross
reference ??
_______________________________________________
BRUCE A. UVANNI BUVANNI@US.IBM.COM
Power PC Product Engineer
PHONE: (802) 769-4042 Tie line (446)
FAX: (802) 769-7147
Sent by: <mike.davis@dcsol.com>
09/28/2005 10:23 PM
Please respond to
rebel-builders
To
cc
Subject
etc??
ignotion
-> Drew
reference ??
The toyota starters are pretty much all the same except for the number of
teeth on the gear. Some have 9 and some have 11. which one you need depends
on the number of teeth on your flywheel. I'll try and find the article I
got my information from on the weekend and report back.
Post by Wayne G. O'Shea » Sat Feb 18, 2012 4:43 pm
Yep...that's a number I'll agree with on a DM style 74" Sensenich. Pretty
sure I have both Howard's and Bob P's "equipment listed" @ 42lbs complete
with spacer/bolts/spinner.....and I actually weighed them!
Sent: Wednesday, September 28, 2005 7:25 PM
Subject: Re: RE: Which o 320 is in your Rebel?
I weighed my Sensenich prop (74x56) and it was 40 lbs. with nose cone,
front and rear plates, spacer and bolts.
PeoplePC Online
A better way to Internet
http://www.peoplepc.com
bransom
Post by bransom » Sat Feb 18, 2012 4:43 pm
I take it then that aluminum isn't the norm for cowls? Surprise to me. What
is the usual?
-Ben/ 496R
Gary Gustafson
Post by Gary Gustafson » Sat Feb 18, 2012 4:43 pm
Several cowls are available:
Aluminum
Murphy's fiberglass regular or speed cowl
Fabricated cowl - fiberglass front end with aluminum and/or fiberglass body
bransom@dcsol.com
Sent: Saturday, October 01, 2005 4:43 PM
What
is the usual?
-Ben/ 496R
