that MAM bought from Rivets Unlimited.... instead of Mattic that they
originally used and now use again. Might have been some RV1414's as
well...but you only get a handful of those with a kit anyhow. Anything else
you have from Murphy should be fine. I don't know who's brand you bought at
Sun n Fun so can't comment on those.
Sent: Monday, November 01, 2004 10:47 AM
Subject: Re: Rivet head bur
yeayTo machine the head nose, do you just use a drill? A 132' or a 118'....
We may do it with the 3/16'' rivet to.... About the "bad" batch of
rivet... with my kit I have receive many type of rivets.... 1/8 and 3/16.
When I make a "bad hole" I had to go for a 3/16 which is big... Las t
myat the Sun'Fun, I have buy some 5/32"(that I have not use yet... may be
any"technic" is better) but they have the "gold" mandrel. Could I use them
forwardway ? Is there oversize compare to a 1/8' will compensate for the ?
quality..
Jean
Rebel 747R
Sent: Monday, November 01, 2004 9:08 AM
youEven easier might be to try putting a few drops of oil into the air line
first. If I forget to do this every thousand rivets or so my puller gets
stiff and doesn't retract (go forward?) all the way...
Wayne G. O'Shea wrote:
Sometimes if the tip is a real close fit this happens...but usually iftake the nose off, unlock the lock nut and move the tip assembly
clearancealittlethread or so...then relock. This lets the tips assembly get pushed amore.further forward when the gun retracts and opens the puller jaws a bitmanagedWayne
Sent: Friday, October 29, 2004 10:56 PM
oroutmandrel
List archives located at:
List archives located at: https://www.dcsol.com/
