Thanks for the input. I'm leaning the same direction you are. I'm also
considering not having a gascolator - and just use the wing drains and a
good auto racing filter in the line. With the rate of fuel burn this engine
has, I would think any water below the wings would go thru the system well
before takeoff. Any thoughts on this from you or others would be
appreciated.
Tom Packard
SR043
Sent: Monday, June 27, 2005 11:48 AM
Subject: Re: lycoming I0-540
don'tHi Tom,
Phil lost his project in a shop fire which is why he hasn't been active on
the list for some time. He was kind enough to reply to me.
Here some of what I've found out about the engine so far. The IO-540's
arerequire a header tank or fuel return but it seems that several builders
I'mstill installing. I suppose this is the "belt and suspenders" approach.
probleminclined to simplify the system and not install, unless someone can point
out definitive advantages of header/fuel return..
The IO-540-G1D5 (290 HP) is similar to the K engines (300 HP) but the G
engines are limited to 2575 RPM and the K engines have the larger
crankshaft. The G1D5 has rear facing air induction which might be a
lightwith the Murphy engine mount. I've talked to Raven Aircraft
http://www.ravenaircraft.com/, they can supply an inexpensive modification
to convert to forward facing which is probably the way to go.
I can get a HC-92WK-1D prop with the engine. This is the matching prop for
the engine. It is a 88" 2 blade prop.
I'm planning on sending the engine to Aerosport Power for inspection and
test run. I'll also have the stock alternator and starter replace with
engine.weight versions. I'm also interested in the E-Mag electronic ignition for
the engine, http://www.emagair.com/. These replace the standard magnetos.
There are two versions, E-MAG and P-MAG. The P-MAG is self powered so you
don't have to worry about an electrical system failure stopping your
*-------------------------------------------------------------------------*They say they are developing a Lycoming 6-cylinder version which will be
available in the fall.
Tim
SR030
Sent: Monday, June 27, 2005 6:27 AM
Phil:
I have the same IO-540 please share with all on the list if you will.
Tom Packard
SR043
Sent: Saturday, June 25, 2005 10:38 AM
wouldHi Phil,
I have the opportunity to purchase a IO-540-G1D5 and matching prop. Iadvancebe
interested in finding out what your experience is with this engine.
Please
contact me
off list.
Tim Saxton
SR030
tim.saxton@shaw.ca
Sent: Monday, April 28, 2003 5:53 AM
Subject: lycoming I0-540
--- http://USFamily.Net/dialup.html - $8.25/mo! --
http://www.usfamily.net/dsl.html - $19.99/mo! ---
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
