lycoming I0-540
jtpackard
lycoming I0-540
Post by jtpackard » Sat Feb 18, 2012 10:43 am
Tim:
Thanks for the input. I'm leaning the same direction you are. I'm also
considering not having a gascolator - and just use the wing drains and a
good auto racing filter in the line. With the rate of fuel burn this engine
has, I would think any water below the wings would go thru the system well
before takeoff. Any thoughts on this from you or others would be
appreciated.
Tom Packard
SR043
Sent: Monday, June 27, 2005 11:48 AM
Subject: Re: lycoming I0-540
Hi Tom,
Phil lost his project in a shop fire which is why he hasn't been active on
the list for some time. He was kind enough to reply to me.
Here some of what I've found out about the engine so far. The IO-540's
don't
require a header tank or fuel return but it seems that several builders
are
still installing. I suppose this is the "belt and suspenders" approach.
I'm
inclined to simplify the system and not install, unless someone can point
out definitive advantages of header/fuel return..
The IO-540-G1D5 (290 HP) is similar to the K engines (300 HP) but the G
engines are limited to 2575 RPM and the K engines have the larger
crankshaft. The G1D5 has rear facing air induction which might be a
problem
with the Murphy engine mount. I've talked to Raven Aircraft
http://www.ravenaircraft.com/, they can supply an inexpensive modification
to convert to forward facing which is probably the way to go.
I can get a HC-92WK-1D prop with the engine. This is the matching prop for
the engine. It is a 88" 2 blade prop.
I'm planning on sending the engine to Aerosport Power for inspection and
test run. I'll also have the stock alternator and starter replace with
light
weight versions. I'm also interested in the E-Mag electronic ignition for
the engine, http://www.emagair.com/. These replace the standard magnetos.
There are two versions, E-MAG and P-MAG. The P-MAG is self powered so you
don't have to worry about an electrical system failure stopping your
engine.
They say they are developing a Lycoming 6-cylinder version which will be
available in the fall.
Tim
SR030
Sent: Monday, June 27, 2005 6:27 AM
Phil:
I have the same IO-540 please share with all on the list if you will.
Tom Packard
SR043
Sent: Saturday, June 25, 2005 10:38 AM
Hi Phil,
I have the opportunity to purchase a IO-540-G1D5 and matching prop. I
would
be
interested in finding out what your experience is with this engine.
Please
contact me
off list.
Tim Saxton
SR030
tim.saxton@shaw.ca
Sent: Monday, April 28, 2003 5:53 AM
Subject: lycoming I0-540
advance
--- http://USFamily.Net/dialup.html - $8.25/mo! --
http://www.usfamily.net/dsl.html - $19.99/mo! ---
--- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! ---
lycoming I0-540
Post by Wayne G. O'Shea » Sat Feb 18, 2012 10:43 am
Install a suitable sized gascolator...everything will go along fine for
maybe years...but then one day someone's gonna die if you don't!!
Requirement is 1 ounce capacity for every 20 gallons.
My 1 cent Cdn worth on the subject!
Sent: Monday, June 27, 2005 5:03 PM
Tim:
engine
appreciated.
Tom Packard
SR043
Hi Tom,
on
don't
are
I'm
point
problem
modification
for
light
for
magnetos.
you
engine.
Tim
SR030
Phil:
Tom Packard
SR043
would
any
need
tee
advance
George Coy
lycoming I0-540
Post by George Coy » Sat Feb 18, 2012 10:43 am
My 2 cents, When I designed my fuel system for the Moose with a 540G1D5
Lycoming, I had a header tank under the floor on the right side at the
firewall. It also had a drain. (acted as a gascolater as the outlet was
screened and an inch above the bottom) I also had a return line to the
header tank with a restrictor from the throttle body. This is to let any air
or vaporized fuel re circulate back to the header tank.
I have experienced several times injected engines that get a drop of air or
fuel vapor in the system. It is the same as shutting off the magneto. It is
not like a carburetor where it will sputter for a few seconds. It is digital
(on or off). It really gets your attention.
Having owned many different injected engine aircraft, I always found a hot
start easier when it has a fuel return line. You open the throttle all the
way, shut off the mixture, and run the boost pump for a few seconds and it
purges the lines in the engine compartment of fuel vapors. (I hope you are
not going to eliminate the boost pump)
The Hartzell prop will require the 5 year overhaul AD. I do not know
Canadian certification rules, but experimental aircraft here in the U.S. the
utilize certified aircraft parts need to follow all Airworthiness Directives
that apply. The same will apply to the Lycoming engine. It will probably
need the oil pump AD, the Fuel pump Ad and the injector lines AD. If it is
graces with Bendix mags, there are a bunch of AD's that need to be complied
with.
George Coy
President
Gesoco Industries Inc.
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Web Site www.gesoco.com
e-mail George@gesoco.com
Franklin County Airport (KFSO)
jtpackard@usfamily.net
Sent: Monday, June 27, 2005 4:03 PM
Tim:
appreciated.
Tom Packard
SR043
Hi Tom,
don't
are
I'm
problem
light
engine.
Tim
SR030
Phil:
Tom Packard
SR043
Hi Phil,
would
be
Please
contact me
off list.
Tim Saxton
SR030
tim.saxton@shaw.ca
advance
lycoming I0-540
Post by Mike Kimball » Sat Feb 18, 2012 10:43 am
I'm not going to use a gascolator. The low point in my installation when
sitting on the ground is under the floor about where the rear seats are. My
fuel lines run inside the rear door posts. Each run (left and right) has a
tee in it before continuing on to the fuel selector valve. The tee goes to
fuel drains in the bottom fuselage, one on each side. The fuel lines run
uphill from there all the way to the carburetor. I am using a V8 so the
carb is on the top of the engine. A Summit Racing fuel filter is in line at
the carb. I would not rely on wing drains alone. You should have a low
point drain.
044SR
Sent: Monday, June 27, 2005 1:03 PM
Tim:
appreciated.
Tom Packard
SR043
Hi Tom,
don't
are
I'm
problem
light
engine.
Tim
SR030
Phil:
Tom Packard
SR043
Hi Phil,
would
be
Please
contact me
off list.
Tim Saxton
SR030
tim.saxton@shaw.ca
advance
lycoming I0-540
The main reason for a gascolator is to seperate water. The screen is a bonus
to filter out larger particles of dirt. Your filter will not remove water
(TTBOMK). Your fuselage low point drains are there to get any water that
gets in the lines while sitting and even then they will only collect a small
amount and generally they never really end up in the low spot and definitely
never if you are on wheels/ floats/amphibs at different times of the year.
The gascolator is there for seperating water both while sitting and while
fuel is going thru the system and hense the FAA's requirement of 1 ounce per
20 gallons of tank. Partially based on how much water might be in fuel, but
mainly based on larger tanks...generally means larger engine for the larger
fuel flow...means less time to seperate...thus larger bowl to get the job
done before the water heads for the engine.
I've said enough.. back into hiding.
Sent: Monday, June 27, 2005 7:16 PM
Subject: RE: lycoming I0-540
My
at
point drain.
044SR
Tim:
engine
appreciated.
Tom Packard
SR043
Hi Tom,
on
don't
are
I'm
point
problem
modification
for
light
for
magnetos.
you
engine.
Tim
SR030
Phil:
Tom Packard
SR043
would
any
need
tee
advance
Bob Fisher
lycoming I0-540
Post by Bob Fisher » Sat Feb 18, 2012 10:43 am
hi tom one of the seldom mentioned benefits of the gascolator is that it
is a great check on the overall condition of the fuel system ahead of it
that is you can see quickly if you have good fuel flow well before you
ever start the engine
i`d vote to leave it in bob fisher rebel 342 amphib
Tim:
engine
appreciated.
Tom Packard
SR043
Hi Tom,
on
don't
are
I'm
point
problem
modification
for
light
for
magnetos.
you
engine.
Tim
SR030
Phil:
Tom Packard
SR043
would
any
need
tee
advance
lycoming I0-540
Post by Bob Patterson » Sat Feb 18, 2012 10:43 am
I'll second that one Wayne !!
One other consideration - maybe not too important for some
of you, but - if you EVER want to sell your aircraft to a Canadian,
it MUST have a gascolator ! Our rules !
AFAIK, one would have to be retro-fitted in order to get registration.
Tim:
engine
appreciated.
Tom Packard
SR043
Hi Tom,
on
don't
are
I'm
point
problem
modification
for
light
for
magnetos.
you
engine.
Tim
SR030
any
need
tee
Tim Saxton
lycoming I0-540
Post by Tim Saxton » Sat Feb 18, 2012 10:43 am
George,
Good point about hot starts. I already have a vent line up the forward door
post. Shouldn't be difficult to install
a small header tank. I'll have a boost pump and gascolator and all of the
AD's will be complied with.
Tim
PS. for those that are using Murphy's Lycoming mounting kit, are you
satisfied with the kit? I know the cowl was a tight fit for the wide deck
engines but it has been redesigned to fit.
Sent: Monday, June 27, 2005 2:59 PM
air
or
is
digital
Directives
complied
with.
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
Tim:
engine
appreciated.
Tom Packard
SR043
Hi Tom,
on
don't
are
I'm
problem
modification
for
light
engine.
Tim
SR030
Phil:
Tom Packard
SR043
would advance
jtpackard
lycoming I0-540
Thanks for all the input guys (George,Mike,Wayne,Bob & Bob and Tim)
Sounds like I will be putting in a gascolator and/or a system like George
has, although I've always wanted to minimize the amount of fuel inside.
George, how big is your header tank? Is if fabricated from 6061-T6 or a
softer Alum, and is it welded or riveted and sealed like the wing tanks, or
does it include a bladder? How and at what points did you attach it to the
fuselage? Also, would you describe the restrictor from the throttle body to
the header tank? Is it off the shelf or did you drill out some fitting to
dim X? Thanks again for your comments/suggestions.
Tom Packard
SR043 w/ Coy/Lyc IO540-G1D5
Sent: Monday, June 27, 2005 4:59 PM
air
or
is
digital
hot
Directives
complied
with.
George Coy
President
629 Airport Rd.
Swanton, VT 05488
TEL 802-868-5633
FAX 802-868-4465
