fiberglass retainer and the fuse. I don't want water getting back under the
fiberglass retainer -- which requires sealant coverage of at least the front
edge of the bottom of the retainer. I'm not keen to use butyl tape sealant
there because I don't want black goo oozing out of the junction between the
front of retainer and fuse on a hot day -- where everything will be white.
I do plan on using butyl tape sealant between the fiberglass retainer and
the windshield itself, and under the sides and top, so even if the Bostick
1100 _is_ tough to remove, it would only be a problem if I had to take the
whole front retainer off the fuse.
If I'm following this thread correctly, although the butyl rubber sealant
tape method is a "known good" material and solution, except for occasional
oozing, we don't have a lot of empirical evidence about how removable the
Bostick 1100 is. Time for some experiments.
Ron
254R
On Fri, Feb 12, 2010 at 7:10 AM, Wayne G. O'Shea <oifa@irishfield.on.ca>wrote:
...CORRECTION !! It was pointed out I may have the wrong culprit. I was
thinking Bostick 1100 is the stuff MAM was shipping for a while after they
stopped putting the tape in the winsdhield install kits. I have realized
Bostick was what Bob P was recommending and not what MAM was shipping and
what the owner of this aircraft confirmed he used. "The tube that came from
MAM".
