What's on the CD was Re: Photos of Door edge?
lawsonb
Post by lawsonb » Sat Feb 18, 2012 1:21 am
Hey Roger,
We've been wondering about getting the CD. Can you give me a rough
idea as to what is "on it"? Cost? Where or how to get it?
TIA
Brian Lawson,
Windsor, Ontario.
EAA Chapter 185 Rebel 528
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
On Tue, 30 Jul 2002 07:01:32 -0800, you wrote:
SNIP
I did recently pickup the manual on CD and I
could send you the section on building the doors.
Roger Hoffman #687R
Eugene, OR USA!
Mike Davis
Post by Mike Davis » Sat Feb 18, 2012 1:21 am
All,
I know this won't be of any help to you Rebel builders, but I have just
zipped up the entire Moose manual CD-ROM. My CD was dated 06/21/02. The
file is 72.5 MB, so be sure you really want it before you try downloading...
even with a cable modem this is going to take a while! The file is located
in the SR2500/Moose Manual Updates file area.
195SR
Sent: Tuesday, July 30, 2002 4:59 PM
Subject: What's on the CD was Re: Photos of Door edge?
Hey Roger,
TIA
Brian Lawson,
Windsor, Ontario.
SNIP
Roger Hoffman #687R
Eugene, OR USA!
rognal
Post by rognal » Sat Feb 18, 2012 1:21 am
Brian,
To be quite honest, I wasn't impressed with the CD. It appears to have simply
been burned onto a blank CD and put into a plastic CD case. Yet Murphy charged
$17.65 USD for a couple dollars worth of plastic and a few minutes of someones
time to copy it.
I bought it thinking it might have a lot of photographs showing details of the
aircraft's construction. You know, photos taken as the aircraft was being
built. But it mostly has only photos of finished aircraft.
The actual builder's manual on the CD may be of use to someone who has an old
manual, but mine is #687 so it is relatively current, so it was of no value to
me. Well, maybe I shouldn't say that...I can now take the manual to work with
me and read ahead using my laptop...heh, heh, heh.
Roger Hoffman #687R
Eugene, OR USA!
RJ Thomas
Post by RJ Thomas » Sat Feb 18, 2012 1:21 am
Mike,
I looked but cannot find the Manual Updates for the SR2500/3500/Moose/? I
can find an empty folder for updates on the Maverick. Am I close?
Cheers, rj
R J Thomas
140SR
Sent: Tuesday, July 30, 2002 8:24 PM
Subject: Re: What's on the CD was Re: Photos of Door edge?
All,
195SR
Hey Roger,
TIA
Brian Lawson,
Windsor, Ontario.
SNIP
Roger Hoffman #687R
Eugene, OR USA!
Mike Davis
Once you click on "Files" you'll want to click on "Super Rebel & Moose", in
this group area 68 is "S Manual Updates". This is where the file is
located... you can also just click on the "New files" button, since it's
just recently been uploaded it will show up here.
Sent: Friday, August 02, 2002 5:28 AM
Subject: RE: What's on the CD was Re: Photos of Door edge?
Mike,
Cheers, rj
R J Thomas
140SR
All,
downloading...
located
195SR
Hey Roger,
TIA
Brian Lawson,
Windsor, Ontario.
SNIP
Roger Hoffman #687R
Eugene, OR USA!
RJ Thomas
Mike,
I went there and looked. I see 67 S Personalities and 72 Flight Seeing but 68 S Manual Updates does not appear.
Coincidentally, if I click on the new files button with the 7 day default, I get a blank listing. I need to go out to 16 days to get one file in that listing (Jim Moore's floatless floatplane). 28 days yields a couple dozen or so.
Thinking that this might be an issue with an old bookmark, I closed the Microshaft(tm) browser (thanks and apologies to bobp) and re-launched it from the link on your e-mail reply. Same results.
Any ideas?
Cheers, rj
Sent: Friday, August 02, 2002 8:44 AM
Mike,
Cheers, rj
R J Thomas
140SR
All,
downloading...
located
195SR
Hey Roger,
TIA
Brian Lawson,
Windsor, Ontario.
SNIP
Roger Hoffman #687R
Eugene, OR USA!
Mike Davis
Thanks for the heads up! It should work fine now... for some reason the security settings didn't take. Some time ago I added file areas for manual updates and service bulletins for each aircraft. Seems only the manual updates area for the Maverick took the security setting correctly. Anyway, I've reset them and checked them, you should be able to access the file fine now.
Sent: Friday, August 02, 2002 6:10 AM
Mike,
Any ideas?
Cheers, rj
RJ Thomas
Mike,
Thanks! I am downloading the file now.
I hope you realize how much we all appreciate your efforts.
Cheers, rj
Sent: Friday, August 02, 2002 9:31 AM
Mike,
Any ideas?
Cheers, rj
Mike Davis
No problem... not only do I have a tremendous resource for my own project which is just starting, but I actually enjoy doing it!
Sent: Friday, August 02, 2002 6:46 AM
Mike,
Cheers, rj
Mike,
Any ideas?
Cheers, rj
