Gull wing doors
Gull wing doors
Post by Wayne G. O'Shea » Fri Feb 17, 2012 9:21 pm
Joel, Curt or Rick Ford are the best to answer that one. Where are you
guys????
Sent: Thursday, October 25, 2001 4:04 PM
Subject: Re: Couple questions.
Where could I find more
information on the gull wing doors? I saw the pic's on Wrays web site and
really like the observer look. I was thinking about using all lexan skins
on the stock doors. What is the benefit of the gull wing style? Easier
seal since it's all one piece?
Joel
Joel Jacobs
Gull wing doors
Post by Joel Jacobs » Fri Feb 17, 2012 9:21 pm
I'm in central Ohio usa. - Joel
Sent: Thursday, October 25, 2001 3:41 PM
Subject: Gull wing doors
guys????
Rebflyer
Gull wing doors
Post by Rebflyer » Fri Feb 17, 2012 9:21 pm
Hi Joel,
I installed gullwing doors on my aircraft, and am quite happy with them.
Pro's? They are up and out of the way for entry, exit, and float ops. I used a bellcrank driving three pins, one forward one aft and one down so the door shuts nice and secure. In the up position the bottom pin goes into a bracket on the the wing. I only ha
d to purchase a few minor pieces to make it work from MAM stock. Along with that, the window is about 2" taller than the original design for great vis. I took extra pains in fitting the skin to the fuse and only had to put one small area of weather seal on th
e co-pilots side because Fife complained so much. The pilots side is fine.
Con's? No window to hang your elbow out. The gullwings in flight open to about a 50deg from the fuse, but I have to lean to far out to push them up against the bottom of the wing, and as you get close the pressure really builds. I never have tried taking o
ff with the doors open. The only other thing is you lose a 2" high 12" long wedge at the doorsill to A post area to allow the door to clear the strut, but that is a non event other than I think it adds some strength to that area(a good thing)
The windows, being larger, really vibrate. I've thought about some bracing, but I hate to lose the view.
Sorry I havn't put together a print of the door yet, but I just havn't had the necessary time. I will get to it someday. When I'm not out flying :) But do keep at it, it's way more fun than should be legal!!! Curt N97MR
wrayt
Gull wing doors
Post by wrayt » Fri Feb 17, 2012 9:21 pm
I seemed to recall snapping a couple of pictures of Curts door so I poked through the stacks and low and behold. I put them here http://wrayt.tripod.com/construction.html under "other stuff". Click on the pictures for larger views. The blurry cat in the hat in
the 3rd picture is Curt himself.
