fuselage parts
Jones, Mike
fuselage parts
Post by Jones, Mike » Fri Feb 17, 2012 8:39 pm
Hi All
Just got list of some parts for forward cage on the rebel and thickness for
these items. Here is current list from murphy for these parts
FUS-7------- .063 6061 T6
FUS-11L---- .020 6061 T6
FUS-11R---- .020 6061 T6
FUS-8------ .063 6061 T6
note some thickness may have changed, they have on kit #007, look at fus-8 &
fus-7
Mike#007
Contributors' page at:
Visit the book store at:
Legeorgen
fuselage parts
Post by Legeorgen » Fri Feb 17, 2012 8:39 pm
Wayne,
I'll go through my old manual tomorrow and verify if my kit was shipped with
fus 70, then let you all know.
Bruce G 357R
fuselage parts
Post by Wayne G. O'Shea » Fri Feb 17, 2012 8:39 pm
Your following message has been delivered to the 180 members of
the list murphy-rebel@dcsol.com at 20:20:40 on 3 Jan 2001.
Bruce, I think maybe Brian Godden must be over worked or having a "brain
gap" and this sure isn't helping you guys and gals with the building
process!!!!!!! Although in all fairness to Brian, I think he built the
earlier Rebels that did have all FUS-10's and may not have updated his
personal "RAM" since joining the factory! I don't know how far back it goes
but, like I said in a previous mail, my aircraft #243 came with (as have any
I know of with serial numbers above that) 6 FUS-10's and 2 FUS-70's. The
manual even spells out that the FUS-10's are used on the upper firewall to
door post, the rear cabin to tail cone and the rear gear fitting to tail
cone transitions. The fus 70's are spelled out on the lower front wraps.
Rumour has it that the new Rebel kits are coming with .032 lower wraps
instead of the FUS-70's to cut the number of parts required in stock, but I
can't confirm that!
Sent: Wednesday, January 03, 2001 8:04 PM
Subject: Re: fuselage parts
Mike,
I talked with Brian from MAM today. He said the Rebel is still shipped
with
.020 corner raps (fus 10) and the Super Rebel is shipped with .032 raps.
Bruce G
Legeorgen
fuselage parts
Mike,
I talked with Brian from MAM today. He said the Rebel is still shipped with
Bruce G
