[rebel-builders] 4 door cowl hingpin
Post by Wayne G. O'Shea » Sun Feb 19, 2012 11:50 pm
Charlie... I've never got the originals back in since the paint job in 1995
I've had the same 8 pins in since. Go to a welding supply house and get a
dozen 0.063 stainless TIG filler rods.
Sent: Friday, May 27, 2011 10:36 PM
Subject: [rebel-builders] 4 door cowl hingpin
Hello All
In reference to the Rebels "4 door metal cowl". Is there anything short of
normal wear and tear that will reduce the force and difficulty required to
thread the hinge pins in and out to open/close the cowl doors. I thought I
read that using a smaller dia. hinge pin would help?
Charlie E. 802R
Charles W. Boekhorst
Post by Charles W. Boekhorst » Sun Feb 19, 2012 11:50 pm
Hi Charlie
I just recently found that apply silicone spray to the hine pin will help
this alot. it works better then oil because it will not wick out and end up
on your windscreen and make you think you have an oil leak.
Have a good one
Charles
Hello All
Charlie E. 802R
mtutt
Post by mtutt » Sun Feb 19, 2012 11:50 pm
Use a cordless drill with the end of the pin in the chuck and just drill it in or out
Sent from my BlackBerry
Charlie Eubanks
Post by Charlie Eubanks » Sun Feb 19, 2012 11:50 pm
I thought I had read to use a smaller wire somewhere. I guess it was one of
your replies to another builder. I happen to have some .062 steel rod (soft)
and it worked a lot better. Do you recommend a SS alloy type that is more
rigid then the other SS types ?
C.W. Boekhorst
I am sure the silicone works better but I have not painted my Rebel and
would not like to take the risk at this time.
Mtutt
I have been using the drill up to now but I have heard that eventually the
hinge rod may get loose and I will have to bend a hook on the end to keep
the rod from vibrating forward in too the prop.
Thanks Guys for all the good replies.
Charlie E. 802R
Sent: Friday, May 27, 2011 9:47 PM
Subject: Re: [rebel-builders] 4 door cowl hingpin
1995
Hello All
Charlie E. 802R
The SS bends pretty easy and gets out of shape.. but so far in 15+ years of
putting those pins in and out I haven't had one break. Straighten it out and
put it back in. The little "wiggles" help take the slop out of the
clearance!! LOL
Sent: Saturday, May 28, 2011 5:58 PM
(soft)
C.W. Boekhorst
Mtutt
Charlie E. 802R
1995
Hello All
Charlie E. 802R
Charlie
Finding away to secure the hine pin is important. im my 12 years in aircraft
maintenance i have seen hine pins that were nearly impossibly to install
vibrate out.
the slickest instlalation i have seen is making the pin slighly shorter then
the hinge and drilling the hing and placing a small cotter pin or lockwire
through the hole.
I finally got back to working on my Rebel today its been too long.
(soft)
C.W. Boekhorst
Mtutt
Charlie E. 802R
1995
Hello All
Charlie E. 802R
Dick Wampach
Post by Dick Wampach » Sun Feb 19, 2012 11:50 pm
The RV people sell a pin with a welded "tab" on one end $6 to 8 each at
VANS. I added a nut plate into the cowl attach points and use a screw to
hold it in place, easy, sanitary, effective. Or just bend a "U" on the end
then the hut plate and screw.
Dick Wampach SR-108 N331RW
Sent: Saturday, May 28, 2011 3:11 PM
Charlie
vibrate out.
through the hole.
one
(soft)
C.W. Boekhorst
and would not like to take the risk at this time.
Mtutt
the hinge rod may get loose and I will have to bend a hook on the end
to keep the rod from vibrating forward in too the prop.
Charlie E. 802R
in 1995 !!
get a dozen 0.063 stainless TIG filler rods.
Hello All
short of normal wear and tear that will reduce the force and
Charlie E. 802R
List archives located at: https://mail.dcsol.com/login username
password "builder"
drewjan
Post by drewjan » Sun Feb 19, 2012 11:50 pm
I never liked how a pin works so I used 4 quarter turn camloc fasteners on each side.
Sender: mike.davis@dcsol.com
Date: Sat, 28 May 2011 17:46:27
Subject: RE: [rebel-builders] 4 door cowl hingpin
Charlie
vibrate out.
through the hole.
one
(soft)
C.W. Boekhorst
Mtutt
Charlie E. 802R
in 1995 !!
Hello All
Charlie E. 802R
password "builder"
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 11:50 pm
Me too. Works great. (See http://n254mr.com/node/1739)
each side.
Jesse Jenks
Post by Jesse Jenks » Sun Feb 19, 2012 11:50 pm
I vote for camlocs too. Mine turned out good that way
Date: Sat, 28 May 2011 22:57:52 -0700
each side.
Hank & Vickie Balch
Post by Hank & Vickie Balch » Sun Feb 19, 2012 11:50 pm
I also put camlocs on my cowl and couldn't be happier. It takes only
seconds to open the cowl and check the engine.
Hank Balch
307R
on
each side.
