[rebel-builders] Scott 2000 tail wheel
N.Smith
Hi Charlie
I've recently come across this as a possible option
http://www.irondesign-airparts.com/tailwheels.htm
Can't vouch for it on an Elite or Rebel but might be worth a look ?
Nig
745E
Charlie Eubanks
Sent: 18 January 2010 16:42
Subject: [rebel-builders] Scott 2000 tail wheel
Hello All
I have looked through the very extensive archives about tail wheels and I
still have a question. Consider the following. I plan to certify my Rebel at
1320 Lbs. and have an old Scott 2000 (6" hard rubber tire) tail wheel off my
Luscombe which I replaced with a new trouble free Scott 2000 15 +years ago,
Today the Scott wheels are hard to fine and are so expensive, I intend to
make the necessary parts and put it back in to service. If I install a steel
spring and the "rebuilt" Scott wheel, it will weigh 8.2 Lbs. or about 2.2
Lbs more then the Rebel wheel & spring that came with my kit. It's not a
fork type tail wheel but is there any reason why this wheel wouldn't work on
the Rebel? Is there anybody who has had success/failure with this wheel on
their Rebel I sure would like to hear from you.
Charlie E. 802R
Nig
745E
Charlie Eubanks
Hello All
Charlie E. 802R
Charlie Eubanks
Thanks Nig
Did not see the weight of the tail wheel on his website so I sent Scott a
e-mail..
Thanks for the info.
Charlie
Sent: Monday, January 18, 2010 12:14 PM
Subject: RE: [rebel-builders] Scott 2000 tail wheel
e-mail..
Charlie
Hi Charlie
Nig
745E
Charlie Eubanks
Hello All
at
my
ago,
steel
on
Charlie E. 802R
Garry Wright
I had a rear fuselage failure on the left side when I required the Scott
2000 (old number 24B) to jump about a 1 1/2" pavement edge. Partly
because of its small diameter, partly because it is hard and partly
because the fuse did not have one of the later reinforcements in the
tail end, I got a couple of wrinkles in the tailcone which were a lot
harder to fix than they are to make up initially. Keep away from little
jumps and it will likely be okay. I think the hard wheels have been
largely successful for most people but not in this case. A common
comment is that the pneumatic tire is a good deal more pleasant to taxi
with and I would second that. I sold my 24B and got the 3200.
Garry
Garry
Hello All
Charlie E. 802R
Ron Shannon
Charlie,
FWIW, I have the Iron Designs tailwheel on a modified Champ spring. It's
very high quality workmanship. I can't say much about how it works yet
though, because the longest I've run it at one time so far is about 8 ft. --
pushing by hand. :) Hopefully, that statistic will get longer before too
long.
254R
On Mon, Jan 18, 2010 at 11:35 AM, Charlie Eubanks
long.
254R
Thanks Nig
e-mail..
Charlie
Charlie Eubanks
You may recall I am going for 1320 Lbs. Just got Scotts reply. The Iron
Design is a nice looking product but it's 4-3/4 Lbs. heaver then the what
came with the kit. Thanks for the help.
Charlie
Sent: Monday, January 18, 2010 2:48 PM
Subject: Re: [rebel-builders] Scott 2000 tail wheel
Charlie
Charlie,
ft. --
long.
254R
Thanks Nig
e-mail..
Charlie
Charlie Eubanks
Garry
Thanks for telling me of your experience. I am afraid at 1320 GW the extra
4-3/4 Lbs.of the 3200 way back there would be to much. I have had good
success with the Scott 2000 on my Luscombe, maybe I could retrofit a
pneumatic tire for it.
Charlie
Sent: Monday, January 18, 2010 2:15 PM
Charlie
Garry
Charlie Eubanks wrote:Hello All
at
my
ago,
steel
on
on
Charlie E. 802R
At 10:42 AM 18/01/2010 -0600, you wrote:
Since you're OK with a solid tire why not just use the MAM tailwheel and
save 2.2lbs. If you don't like it after flying for a while it's not
something that would be difficult to change later.
There's nothing wrong with the murphy tailwheel other than the solid tire.Hello All
Charlie E. 802R
At 06:14 PM 18/01/2010 -0000, you wrote:
and it's a good strong tailwheel but it's not light.
You can also build it yourself from plans by Bob Barrows. That's what I didHi Charlie
Nig
745E
