[rebel-builders] wing attach
Ted Waltman
Post by Ted Waltman » Sun Feb 19, 2012 5:54 pm
Dave,
From the manual, "Please note the rear spar fittings are not bolted up tight
when fitting the wings. The wing fittings
"float" inside the fuselage fittings." (so no spacers).
Yes, rear spar attach hole is 3/8"
Ted
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of David
R. Greaton
Sent: Monday, January 04, 2010 2:48 AM
To: rebel builbers list
Subject: [rebel-builders] wing attach
Re: Moose 3500
Do the rear wing attach bolts remain the same 3/8" or are they larger also?
What is used for spacers on the rear wing attach?
Thanks Dave Greaton
Moose 189
David R. Greaton
Post by David R. Greaton » Sun Feb 19, 2012 5:54 pm
Thanks Ted,
I did read that. I thought whereas it said during fit up, it may be tight
at a later time. Probably just trying to read too much into it.
Dave Greaton
Moose 189
Sent: Monday, January 04, 2010 8:52 AM
Subject: RE: [rebel-builders] wing attach
Dave,
tight
Ted
David
R. Greaton
Re: Moose 3500
also?
Thanks Dave Greaton
Moose 189
