corrosion info
Jones, Mike
corrosion info
Post by Jones, Mike » Fri Feb 17, 2012 11:27 pm
Hi all
I took my landing gear apart last week in order to put fuselage in my garage
and when I removed all the bolts there was alot of white powder which
covered the bolts and aluminum parts. Is this corrosion ? If corrosion is
there something that should be put on bolts and aluminum in order to protect
them before assembly ??
Mike#007
EOM
corrosion info
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:27 pm
Your following message has been delivered to the 162 members of
the list murphy-rebel@dcsol.com at 12:20:02 on 16 Oct 2000.
YES! and when you put back together coat bolt, etc. with grease or LP3.
Sent: Monday, October 16, 2000 11:11 AM
Subject: corrosion info
Hi all
garage
protect
Mike#007
EOM
confidential
