I am now at the step of last cleaning before rivet/proseal the gas tank.... On the solid main rib, for the 3 flanges that we rivet/proseal (for gas level sight and gas output) the manual don't show nothing about the hole we should do at the bottom of those flange. Should I make them now or if I let it like that (to bo done later at a another step)? Manual is so clear......
Jean
Rebel 747R
question...
question...
is so clear......
Probably doesn't matter if you wait but it could be tough to drill without
damaging the threads on the flange.
tank.... On the solid main rib, for the 3 flanges that we rivet/prosealI am now at the step of last cleaning before rivet/proseal the gas
is so clear......
I drilled the holes before pro-sealing and rivetting the flanges on.Jean
Rebel 747R
jean.poirier
question...
Hello,
I am working on the tail section of the fuselage (Rebel).
Before making the floor, the manual send me to the float attache point
#12.27. At 12.27.22, the manual ask to rivet the bulkhead "doubler"
to the outer corner wrap... but that corner wrap is still drill to #40 and is not
riveted in the others location.... Look "bizarre" and I would like to double
check...
Please let me know....
Jean
Rebel 747R
check...
Jean
Rebel 747R
