Rebel: Horiz stab span
pequeajim
Post by pequeajim » Sun Feb 19, 2012 1:22 pm
I'm here at work and do not have the data for something I am trying to figure
out. Can anyone tell me the span of the horizontal stab?
Jim!
NormIsler
Post by NormIsler » Sun Feb 19, 2012 1:22 pm
Jim-
A piece of literature I have here shows the Rebel elevator span at 110"
Hope that helps!
Norm Isler
Elite 702E
Post by Wayne G. O'Shea » Sun Feb 19, 2012 1:22 pm
Gotta be close as I don't worry about the elevator tips hitting the swim
ladder as it is just narrower than the float spread when up against the dock
and that's ~ 115". I'll measure for you shortly so you know...and if it's
shop space you are worried about each side comes off seperate and is a 5
minute job to remove/install.
Sent: Friday, February 10, 2006 1:21 PM
Subject: Re: Rebel: Horiz stab span
Jim-
Hope that helps!
Norm Isler
Elite 702E
pequeajim
Thanks guys. I thought it was over 100" and that is too wide for my garage
door, however, you make a great point. I can put them on, setup my control
cabling and leave them on untill I have to move it out of the garage. I am
putting up a building in a month that will allow me to completly assemble the
aircraft before breaking it down to take to the airport. I can work on it until
then.
(Of course the building is going to be for my truck, and tools and stuff,
right....?)
grin...
On 2/10/2006 9:30 AM, oifa@irishfield.on.ca wrote to rebel-builders:
-> Gotta be close as I don't worry about the elevator tips hitting the swim
-> ladder as it is just narrower than the float spread when up against the
dock
-> and that's ~ 115". I'll measure for you shortly so you know...and if it's
-> shop space you are worried about each side comes off seperate and is a 5
-> minute job to remove/install.
-> From: <NormIsler@aol.com>
-> Sent: Friday, February 10, 2006 1:21 PM
-> Subject: Re: Rebel: Horiz stab span
-> > Jim-
-> > A piece of literature I have here shows the Rebel elevator span at 110"
-> > Hope that helps!
-> > Norm Isler
-> > Elite 702E
Post by Bob Patterson » Sun Feb 19, 2012 1:22 pm
Hi Jim !
You don't have to worry about getting it through a door - the
Rebel stab was designed to FOLD ! Just undo the struts, loosen
the bolts, and swing the sides up against the vertical fin ...
put a bungee around to hold it, and roll it inside.
figure out. Can anyone tell me the span of the horizontal stab?
Jim!
pequeajim
Thanks for that tid bit Bob. I did not know that! That will allow me to work
on the tail section outside while I get everything attached and then roll it in
and put it back in place! Cool!
I have enough room in the garage to unfold the tail and then work on the
controls.
I'll do it!
On 2/10/2006 11:00 AM, beep@sympatico.ca wrote to rebel-builders:
-> Hi Jim !
-> You don't have to worry about getting it through a door - the
-> Rebel stab was designed to FOLD ! Just undo the struts, loosen
-> the bolts, and swing the sides up against the vertical fin ...
-> put a bungee around to hold it, and roll it inside.
-> ......bobp
-> -------------------------------orig.-------------------------
-> On Friday 10 February 2006 01:15 pm, pequeajim@dcsol.com wrote:
-> > I'm here at work and do not have the data for something I am trying to
-> > figure out. Can anyone tell me the span of the horizontal stab?
-> > Thanks
-> > Jim!
You also have to unbolt the push pull tube from the elevator horn before
"folding".
Sent: Friday, February 10, 2006 6:48 PM
work
it in
controls.
I'll do it!
-> Hi Jim !
-> ......bobp
-> > Thanks
-> > Jim!
