My second question -- then I'll be quiet for a while: regards the wet wings.
I am considering sandwiching the tank skins under the wing skins instead of
trimming off a large chunk of wing skin, as per the directions.
My calculations indicate a total weight penalty of about 5 lbs. It would
eliminate the cut edge of the wing skin facing the airflow and seem, to me,
to make a stronger tank.
Again, has anyone tried this and is it a BAD idea?
Thanks again,
John...
Fly too low or too slow and the ground will rise up and smite thee.
Wet wing question
Wet wing question
BAD idea...IMHO. There was a guy on the list by the name of Bryan I believe.
Him and his dad chased leaks for ever between the wing skin and tank skin.
I'm sure you could make it leak proof but would be lots of extra prosealing
to be sure you didn't have rivets that leached thru and out between the
skins.
Another suggestion for you would be to pretty much ignore that new manual
you sprang for! It is only going to confuse you doing the tanks with a kit
from '94...unless you also cut yourself some new larger tank skins from .040
to allow you to build it per the new manual.
Welcome to the madness John!
Sent: Wednesday, January 12, 2005 1:01 PM
Subject: Wet wing question
skins.
wings.My second question -- then I'll be quiet for a while: regards the wet
ofI am considering sandwiching the tank skins under the wing skins instead
me,trimming off a large chunk of wing skin, as per the directions.
Thanks again,
John...
Al Paxhia
Wet wing question
Hi John,
I can't respond to the Rebel specific question, but about the 5 lbs. Save
every little bit of weight now because later those little increases can
affect your performance. My airplane has gained 100 lbs. a few pounds at a
time.
Al
Moose, N526AP
Sent: Wednesday, January 12, 2005 10:01 AM
time.
Al
Moose, N526AP
wings.
me,
Thanks again,
John...
Jones, Michael
Wet wing question
hi wayne
i had same problem with new and old manual confusion when doing my tank
skins, none of the dimes works and skins where not size manual said they
should be what a pain in the ###
mike#007
Sent: Wednesday, January 12, 2005 1:13 PM
Subject: Re: Wet wing question
skins.
mike#007
skins.
Thanks again,
John...
