murphy-rebel Digest for 7 Jan 2000
Scott
Post by Scott » Fri Feb 17, 2012 8:39 pm
Bob, that is exactly the tool I was looking for. I went to Homebase
(can you believe it?) and found one for $12. I'll cut the hole
tomorrow. Thanks.
Scott, In regards to cutting the access holes in the skins, I had =
purchased some time ago a fly type cutter from (Canadian Tire) of all =
After removing the center slug (they may make nice =
washers some day) a quick run around with the deburring tool leaves a =
perfect hole.-Hope this helps-Bob J.
Kind Regards
Scott
hibbs@pacifier.com
Tim Carter
Post by Tim Carter » Fri Feb 17, 2012 8:39 pm
Scott:
That is the correct tool, and the procedures are correct that Bob
recommends.
Be careful tho, they call it the 'widow-maker' at Boeing. Don't get your
fingers near it when hand-tightening the chuck, stand back, and always wear
safety goggles.
For extra support, especially on the thin .20 wing skins, I always use a 1
ft. sq. plywood backing plate inder the skin.
Tim
#438R
Sent: Saturday, January 08, 2000 6:13 AM
To: (Murphy Rebel Builders List)
Subject: Re: murphy-rebel Digest for 7 Jan 2000
tomorrow. Thanks.
Kind Regards
Scott
hibbs@pacifier.com
