[rebel-builders] battery placement
Post by Drew Dalgleish » Sun Feb 19, 2012 5:29 pm
At 11:45 AM 14/08/2009 -0400, you wrote:
Another question.Should the weight and balance be done to determine
where the battery should go.I'm ready to install the battery now but
have not recieved landing gear parts from MAM.Yes it looks a little
funny ,an almost complete aircraft sitting on a bench.The battery will
be in the back.Is there a location that seems to be universal(fore and
aft)?
Jason
817R
Best to wait till you do the weight and balance then put the battrey where
it's needed.
Rebecca Brownell
Post by Rebecca Brownell » Sun Feb 19, 2012 5:29 pm
Thanks Drew
Jason
will
aft)?
Jason
817R
where
it's needed.
WALTER KLATT
Post by WALTER KLATT » Sun Feb 19, 2012 5:29 pm
I still have my battery (Odyssey) on the front of my firewall (cut back 3 inches) even with my 360. But I do have a survival kit and my ELT stuffed as far back as possible in the tail. Although my empty c of g (10.7, IIRC) is quite forward, it works out well in flight, and allows me to carry lots of baggage.
Date: Friday, August 14, 2009 10:07 am
Subject: Re: [rebel-builders] battery placement
determine
now but
little
battery will
universal(fore and
aft)?
Jason
817R
battrey where
it's needed.
Bob Palmer
Post by Bob Palmer » Sun Feb 19, 2012 5:29 pm
I wanted to figure it out ahead of time too except there are two many
variables. I'm with Walter on the forward C of G. Although it may not be
optimum it may be more practical if you want to haul any bulky loads.
Bob
773E
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 5:29 pm
Mine is 11.92" aft. I find with just me in the airplane, I can't use the
last notch of flaps, not enough elevator to bring the tail down when
landing. I'm afraid on grass I could prop strike it, especially if there is
drag on the tires. Which brings my next comment on the 8.50 tires, they have
quite a bit more drag over the 8.00. I would be in big trouble if I had them
on this plane.
Elite 771
Palmer
Sent: Friday, August 14, 2009 5:38 PM
Bob
773E
baggage.
Post by Walter Klatt » Sun Feb 19, 2012 5:29 pm
The Elite is even better for c of g with the heavier tail. On wheels, it was
harder to get my tail down for landing with full flaps when solo, but on
floats the forward c of g doesn't matter. It does save some weight to have
the battery in front.
BTW, I have had my little 13 lb Odyssey (PC625) now for 9 years, and still
not showing any signs of weakness. I even ran it dead last summer at the
lake when I left the master on, and it didn't seem to damage it.
Palmer
Sent: August 14, 2009 3:38 PM
Bob
773E
baggage.
