[rebel-builders] metal, wood, or composite prop
Karen McCaffery
Post by Karen McCaffery » Sun Feb 19, 2012 5:29 pm
Curt, What is the diameter of your Catto 3 blade prop. I believe I read in the MAManual that the Rebel needs at least a 70 inch diameter prop to be efficient due to the fuselage being fairly wide. Is this really the case? Cris
Sent: Thursday, August 13, 2009 6:24 PM
Subject: Re: [rebel-builders] metal, wood, or composite prop
Gary,
? My Rebel is an 0-320A2B 150 hp powered with one Electric ignition, one mag. I have no idea about a ?Sensenich prop, but I'm faster out of the water than my friends Prince powered Rebel, and I cruise about the same speed.
?? Curt Martin
??? N97MR
Sent: Thu, Aug 13, 2009 2:49 pm
Subject: RE: [rebel-builders] metal, wood, or composite prop
What kind of Lycoming engine and does the performance compare with
That of a Sensenich prop?
Rebflyer@aol.com
Sent: Wednesday, August 12, 2009 6:28 PM
Hi Chris,
I have flown with a Warp drive 3 and 4 blade and am now flying with a
Catto 3 blade that I love. A lot of others are flying the Prince prop.
I have not experienced any flat spot with any of them. The Warp just
didn't like the 4 cyl Lycomings at low idle speeds due to the style of
construction, but that was the prop, no effect on engine performance.
I really like the fact that my Catto weighs 13 lbs.
Sort of thinking out loud (or with letters,), how much time does anyone
spend at that rpm? Maybe on decent for landing, but throttle response is
immediate, on take off the only time I've had a slight stumble is when I
should have leaned a little for density altitude, but 10 sec later I'm
airborne
off water, I guess I'm curious where this thought even came from.
Playing with race cars a lighter flywheel gave much quicker rpm.
Guess I'm just rambling
Curt N97MR
