[rebel-builders] SR Wheels and brakes
Post by Bob Patterson » Sun Feb 19, 2012 5:21 pm
Hi Mike !
The wheels & brakes are all JDM's - made by Murphy. The linings
are compatible with Clevelands, but much cheaper from Rapco.
These are the same wheels & brakes as the Rebel, except you
have 2 calipers.
I'm sure we'll find a buyer for you - just might take a while
in this economy !! :-( Be a lot easier when/if it is in the
lower 48 ... Is the time flown off, so you can ferry it down ??
bobp@prosumers.ca
On Saturday 04 April 2009 18:39, Mike Kimball wrote:
[quote]I have an older Super Rebel (S/N 044). How can I identify what
manufacturer of wheels I have? How about the brake calipers and rotors?
Other
manufacturers compatible? I
Post by Mike Kimball » Sun Feb 19, 2012 5:21 pm
Thanks Bob. Yep, the time is flown off and I can deliver it wherever. I'll
be flying it to Denver later in the year if it hasn't sold where Ted Waltman
has graciously offered to help me sell it from there.
Is it the same JDM brake assemblies in the Aircraft Spruce catalog? I still
can't figure out which brake caliper, rotor, bearings, linings I would order
if I needed replacements.
Patterson
Sent: Saturday, April 04, 2009 11:54 AM
Subject: Re: [rebel-builders] SR Wheels and brakes
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
Post by Wayne G. O'Shea » Sun Feb 19, 2012 5:21 pm
They are not the same.. the SR.. or at least the one I have here have 1 1/2"
ID Bearings.. the Rebel has 1 1/4" bearings.
Pads are 66-106's.. from memory.. but my brain's a little frazzled after
fixing boat hulls all day.
Mike when I shipped that Rebel to Maui... that I sent you pictures of...
total cost for him was just shy of $11,000. That was truck to bring
container to me.. truck to take it to Toronto.. train to Vancouver and down
to Los Angeles and then boat to the big island and then off load and shuttle
boat to Maui.
Sent: Saturday, April 04, 2009 3:54 PM
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
manufacturers compatible? I'd like to know what the brake linings are as
well so I know what to get when they wear out. I have 8.00-6 tires now.
I'm assuming I can use 8.50-6 tires if I want? True? I'm also assuming
that the axles are 1
66-106 is a really common lining. That's probably correct. Is it just
different bearings or are the wheels different?
The 20 foot container cost from Fairbanks to Armidale, Australia was $17K so
it's starting to sound like I'm likely not going to get a better price by
much in today's dollars all the way to Australia. Even with the stinger,
cowl, and engine mount off, the fuselage is still 21 feet long. Even angled
in the container I doubt the 20 foot container will work. I think $26K is a
deal breaker for the "take it to Australia" idea.
G. O'Shea
Sent: Saturday, April 04, 2009 1:41 PM
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
I'll grab the wheels, from the marine container the SR is in, tomorrow and
get bearing numbers off of them if I can... and compare to the Rebel JDM
wheels I have in the shop as well Mike.
Sent: Saturday, April 04, 2009 8:32 PM
Subject: RE: [rebel-builders] SR Wheels and brakes
[quote]66-106 is a really common lining. That's probably correct. Is it just
so
angled
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
Sure appreciate it Wayne. Don't un-package the whole container just for
this. I'm sure I can figure it out myself. Just thought if the numbers were
handy...
G. O'Shea
Sent: Saturday, April 04, 2009 4:42 PM
so
angled
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
There sitting inside the door in a box.. easy to get to.. Fus is in one
container... wings/feathers etc in another.
Sent: Saturday, April 04, 2009 9:18 PM
[quote]Sure appreciate it Wayne. Don't un-package the whole container just for
were
handy...
G. O'Shea
so
angled
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
as
Mike.. as Bob stated they are (almost) the same wheels as the Rebel/Elite.
Same in all measurements EXCEPT the bearing bore is machined bigger. Axle is
1.5" on the SR/Moose.. 1.25 on the Rebel.
Bearings in the SR wheels that I have.. tapered rollers are KOYO HI-CAP
JL-69349-N and it's matching cone that fits a 2.5" bore. I didn't remove the
cone to get a number.
Glad I actually looked for you. The one bearing I pulled the dust seal off
etc to remove.. found the cone had been installed with a screw driver or
chisel. Sharp marks in two spots on the cone edge so deep that they bulged
the cone and two deep nicks in the cone face itself. !!$$$%&&**%*(!!!
Pads are definitely 66-106's
were
handy...
G. O'Shea
so
angled
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
as
Much thanks Wayne. Wonder if I should pull my bearings to check the cones!
G. O'Shea
Sent: Sunday, April 05, 2009 2:22 PM
were
handy...
G. O'Shea
so
angled
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
Other
as
It's actually a 2.48 OD bore and ID 1.4961.. Found Timken and NSK have the
same bearing number as well as KOYO. Bearing and cone appears to be
JL-69349/10 at least at NSK... the company Curt was looking for the other
day.
http://www.nskf-bearings.com/Products.htm
With Timken.. I believe the cone number is JL-69310.. so a set is
JL-69349/JL-69310
Sent: Sunday, April 05, 2009 6:22 PM
[quote]Mike.. as Bob stated they are (almost) the same wheels as the Rebel/Elite.
is
were
handy...
G. O'Shea
$17K
so
by
angled
is
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
rotors?
Other
as
now.
If you don't hear clicking pushing it... you're probably just fine!
Sent: Sunday, April 05, 2009 6:42 PM
[quote]Much thanks Wayne. Wonder if I should pull my bearings to check the cones!
G. O'Shea
is
were
handy...
G. O'Shea
$17K
so
by
angled
is
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
rotors?
Other
as
now.
No clicking. Thanks for the tip though. Speaking of pushing it, one person
pushing a Moose/SR around by themselves is no small feat! I've been using my
truck and a rope to turn it around once in a while to melt the ice off the
windshield using the power of the sun. I can't do it myself. By the way, my
neighbor at the airport told me how he used a hair dryer to melt the ice off
of his windshield and caused a small, permanent warpage doing it. I thought
of doing that myself and probably would have been fine with my 1/4 inch
windshield, but word to the wise for those of you with a standard thickness
(thin) windshield ...
G. O'Shea
Sent: Sunday, April 05, 2009 2:46 PM
G. O'Shea
is
were
handy...
G. O'Shea
$17K
so
by
angled
is
G. O'Shea
1/2"
down
shuttle
boat to Maui.
[quote]
Hi Mike !
have 2 calipers.
bobp@prosumers.ca
rotors?
Other
as
now.
