of those. Make yor clearance go from nil to comfortable in a
heartbeat. Will also increase yor usefull load by emptying yor
pocketbook! ;)
On 3/12/09, Ted Waltman <tedwaltman@i1ci.com> wrote:
Simply raised the tail until a laser-level on the cabin floor was at 0*.
Interesting to see how high the tail has to go to get to level attitude.
Also interesting to see how much prop clearance I have w/ the plane in level
attitude (~ 12" ).
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of kyle
martin
Sent: Thursday, March 12, 2009 10:55 AM
Subject: Re: [rebel-builders] SR/Moose: Factory (manual) weight & balance
Another addition to all this madness: what do you guys use for a means
of leveling the ac in a level flight attitude?
I was assuming door posts but thought there maybe another.
On 3/11/09, Mike Kimball <mkimball@gci.net> wrote:orI would think that would depend on whether it's around a belly like minesittingone like Pierce Brosnan.
044SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Tim
Hickey
Sent: Wednesday, March 11, 2009 6:00 PM
I think an accepted standard as to where to measure for the cg of abyperson is to measure where the belt buckle is located.
Tim Hickey.
R808
To: "Rebel Builder's List" <rebel-builders@dcsol.com>
Sent: Wednesday, March 11, 2009 8:46 PM
Subject: RE: [rebel-builders] SR/Moose: Factory (manual) weight & balance
Ted was trying to protect me from embarrassment over measurement errorssomeonecorresponding with me directly. Appreciate it Ted but not to worry. I
don't
mind fessing up if I made a boo-boo especially if it could lead toelse using bad numbers. I still advocate everyone making your own
measurements. Differences do exist between different builders and pilot
preferences for seat position as mentioned below.
I went and re-measured today. Here's what I got this time:
Pilot - 20 inches
Passengers - 58 inches
Baggage - 81 inches
Rear Baggage - 118 inches
