[rebel-builders] Best Tailwheel ?
mike jones
Post by mike jones » Sun Feb 19, 2012 5:20 pm
I got a Murphy tail wheel and will see cheap to get ride of it if you want
it
Mike#007
rwatson@dcsol.com
Sent: Wednesday, March 11, 2009 8:27 PM
Subject: [rebel-builders] Best Tailwheel ?
I need to replace my standard tailwheel assembly on my Rotax 100h.p.
Murphy Rebel
What would you guys suggest is the best value for money replacement?
Many Thanks
Bob Watson
Scotland
Post by Drew Dalgleish » Sun Feb 19, 2012 5:20 pm
Murphy Rebel
Many Thanks
Bob Watson
Scotland
Do you have access to a lathe? I built a tailwheel from plans by Bob
Barrows for under $50. Ken reported recently that his Matco wheel is
working well or I can sell my old murphy wheel cheap.
N.Smith
Post by N.Smith » Sun Feb 19, 2012 5:20 pm
Hi Bob
You just bought TK ? :-)
There's quite a few mentions of the Scott tail wheel in the archives,
although I've not done it myself.
Nigel
745E
England
rwatson@dcsol.com
Sent: 12 March 2009 00:27
Murphy Rebel
Many Thanks
Bob Watson
Scotland
Keith Oliver
Post by Keith Oliver » Sun Feb 19, 2012 5:20 pm
Speaking of tailwheels......What is the opinion/assessment of the tailwheel
for the Elite ?
N.Smith
Sent: Thursday, March 12, 2009 7:59 AM
Subject: RE: [rebel-builders] Best Tailwheel ?
Hi Bob
Nigel
745E
England
rwatson@dcsol.com
Murphy Rebel
Many Thanks
Bob Watson
Scotland
N.Smith
Hi Keith
I'm still building, but the Elite supplied wheel seems more substantial than
the rebel one I saw a few years ago. Having said that, mine still needed to
be dismantled and greased up fully to get a nice free feel to the mechanism.
Still a while away from being able to taxi and see what it behaves like
though.
Nig
745E
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Keith
Oliver
Sent: 12 March 2009 14:24
for the Elite ?
N.Smith
Hi Bob
Nigel
745E
England
rwatson@dcsol.com
Murphy Rebel
Many Thanks
Bob Watson
Scotland
henri monnin
Post by henri monnin » Sun Feb 19, 2012 5:20 pm
Best tailwheel,
bransom
Post by bransom » Sun Feb 19, 2012 5:20 pm
The tailwheel debate comes up from time to time, but I don't recall ever
hearing directly about a Rebel groundloop. Henri, if you don't mind
elaborating ...what was it about the Rebel tailwheel that helped lead to a
ground loop?
-Ben/ 496R
On 3/12/2009 1:11 PM, hmonnin2000@yahoo.com wrote to rebel-builders:
[quote]Best tailwheel,
Mike Betti
Post by Mike Betti » Sun Feb 19, 2012 5:20 pm
I have the upgraded Elite tail wheel on my Elite and I like it. Like Ralph
said there is an issue with the mounting on an Elite. Mine is angled what
appears to be backward in my thinking. The only problem I have is if the
wheel is reversed and I need to lock it back in, I don't have enough brake,
but that's a brake issue. It is now a habit for me to just straighten the
wheel to it's normal position after moving the aircraft by hand. I usually
keep it well greased too so it breaks easier. I think it's perfect.
Mike Betti
771ME
Oliver
Sent: Thursday, March 12, 2009 9:24 AM
for the Elite ?
N.Smith
Hi Bob
Nigel
745E
England
rwatson@dcsol.com
Murphy Rebel
Many Thanks
Bob Watson
Scotland
bransom
I'm interested. Can you point me to more info on this?
-Ben/496R
bransom@ucdavis.edu
Kevin & Nancy Mayville
Post by Kevin & Nancy Mayville » Sun Feb 19, 2012 5:20 pm
I purchased a 6'' Matco pneumatic tail wheel to replace the solid wheel that
came with the kit. I have yet to install it since I think I have to replace
the spring since it has a single mounting hole ( compared to the one I have
with is mounted with two bolts ) and I don't think I can redrill the spring.
I like the looks of the Matco wheel and a friend had a solid Matco on his
T18 which worked fine.I think the pneumatic will help smooth the bumps out
of taxing on the asphalt.
Kevin Mayville
C-FRFP
Sent: Thursday, March 12, 2009 6:23 PM
Subject: Re: [rebel-builders] Best Tailwheel ?
ground loop?
-Ben/ 496R
Best tailwheel,
I did not like the way the tailwheel was responding on my Rebel and after
experiencing a couple of ground loops, I changed it to an Alaskan
Bushwheel
P# ABI-3200. It is comparable to the Scott tailwheel but less expensive.
Henri
Canada
Date: Wednesday, March 11, 2009, 5:26 PM
Murphy Rebel
Many Thanks
Bob Watson
Scotland
Post by Ken » Sun Feb 19, 2012 5:20 pm
I looked at that seriously but the Matco 8" with the same tire and tube
as the Scott 3200 was cheaper at around US$220, ready made, and works
fine as per my previous post. Matco said some Bearhawks use it and it is
good for 700 lbs tail weight. The large sweepback on the Barrows will
load the tailspring more which might be a concern if using the
fibreglass spring. The Barrows uses ball bearings instead of bronze
bushings to swivel but some friction is needed there anyway and the
Matco lets you adjust it.
I believe a google on Bob Barrows tailwheel or Bearhawk tailwheel will
find the one Drew mentioned.
bransom@dcsol.com wrote:
-Ben/496R
bransom@ucdavis.edu
Joe Ronco
Post by Joe Ronco » Sun Feb 19, 2012 5:20 pm
BEN: Here is a link to buy the drawings.
http://bearhawkpatrol.tripod.com/bearhawk/id3.html
Here is another link to see what the Barrows tail wheel looks like
readymade.
http://www.irondesign-airparts.com/
Hope this helps.
Joe Ronco
bransom@dcsol.com
Sent: Thursday, March 12, 2009 7:12 PM
-Ben/496R
bransom@ucdavis.edu
Ron Shannon
Post by Ron Shannon » Sun Feb 19, 2012 5:20 pm
FWIW, The Bob Barrows design wheel is made commercially by
http://www.irondesign-airparts.com<http://www.irondesign-airparts.com/Tailwheels.htm>
The price has gone up a bit since I got mine two and half years ago, they're
now $643 complete. I haven't taxied or flown it yet, but the quality is
superb. I have it on a slightly modified Champ tailspring. I'm looking
forward to a Cadillac ride. :-)
Ron
254R
Ian Donaldson
Post by Ian Donaldson » Sun Feb 19, 2012 5:20 pm
G'day from Australia
I would just like to offer these experiences that I had with the standard MAM
tail wheel.
Despite my best efforts at care and maintenance the assembly wore quickly and
eventually broke. The steering arm, where the rudder cables are connected became
disconnected from the main shaft and of course it caused a monumental ground
loop, but thankfully there wasn
Others have pointed out the link. I should add that mine was so cheap
because I was able to find some scrap steel and I'm using one of the
nosewheels off my floats for the rim and tire. The drawings were $25 and
are well worth it just to see how it's made.
At 05:12 PM 12/03/2009 -0800, you wrote:
-Ben/496R
bransom@ucdavis.edu
