Hi all
I took my landing gear apart last week in order to put fuselage in my garage
and when I removed all the bolts there was alot of white powder which
covered the bolts and aluminum parts. Is this corrosion ? If corrosion is
there something that should be put on bolts and aluminum in order to protect
them before assembly ??
Mike#007
EOM
NOTICE - This message is the property of HATCH. It may also be confidential
and/or privileged. If you are not the intended recipient of this message
you are hereby notified that you must not disseminate, copy or take any
action with respect to it. If you have received this message in error
please notify HATCH immediately via mailto:MailAdmin@hatch.ca.
corrosion info
corrosion info
Your following message has been delivered to the 162 members of
the list murphy-rebel@dcsol.com at 12:20:02 on 16 Oct 2000.
YES! and when you put back together coat bolt, etc. with grease or LP3.
Sent: Monday, October 16, 2000 11:11 AM
Subject: corrosion info
garageHi all
protectand when I removed all the bolts there was alot of white powder which
confidentialthem before assembly ??
Mike#007
EOM
*---------------------------------------------------------------------------and/or privileged. If you are not the intended recipient of this message
*---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
