rivet it on the flat to the flap rib and the first bulkhead behind the spar
carrythrough mines abour 2"x4" with the back corner cut off.
At 03:21 PM 10/14/00 -0230, you wrote:
today and haveI just got around to starting the flaperon teleflex cable installation
retainernoticed that some detail is missing. The procedure refers to a 'teleflex
part #) that fit(31509)' ... now I'm guessing that would be 1 of the 2 clamps (different
the dimension ornicely around the cable ..? Or, am I missing something? Also, what is
would guess thatshape of the .125 doubler we are to make for attaching this retainer. I
rivetsthe doubler should be rectangular or maybe triangular in shape, with a few
... close?attaching it to the flap rib, extending down below the rib about 1 inch
---------*Please advise.
Thanks.
Clay
Click here for Free Video!!
http://www.gohip.com/freevideo/
