Grove spring gear / Elite
Post by Ralph Baker » Fri Feb 17, 2012 8:27 pm
Has anyone had any experience fitting Grove spring gear (one piece) to
replace the standard Elite 2 piece gear? This would seem to better
distribute the forces.
Elite 611E
Post by Bob Patterson » Fri Feb 17, 2012 8:27 pm
Hi Ralph !
Haven't heard of anyone doing this, but it DOES sound like
it might be a good idea. You would have to clamp the gear on with
large U bolts at the fuse sides, leaving the center free (ala Zenair).
I think the flex at the center is what saves the structure...
The Citabria also uses these bolts - and this is a DAILY inspection
item, as they tend to crack about every 100 - 200 hours, or so, in
heavy service (glider towing on rough grass fields - I was maintenance
director of a large gliding club for many years ...).
That reminds me - for those of you using steel leaf springs
on the tail - our Super Cubs would break one or more leaves every
couple of months !! We started buying leaf spring sets in bulk, and
inspecting daily - this helped reduce the damage to the rudders !!
....bobp
---------------------------------orig.---------------------------------
Elite 611E
rebelair
Post by rebelair » Fri Feb 17, 2012 8:27 pm
Hi Ralph
I have not seen this but my buddy & I have discussed the possibility. I
ordered a tailskid from Grove & he was great to deal with. He delivered
exactly what he promised. I just recently fitted it replacing my fiberglas
tailskid. Please post any details which you may have.
Brian #328R
Sent: Friday, October 13, 2000 12:00 AM
Subject: Grove spring gear / Elite
Elite 611E
A G Yeoman
Post by A G Yeoman » Fri Feb 17, 2012 8:27 pm
Hi Ralph,
I did think about the one piece gear for my Rebel, thinking
along the same lines as yourself. It would dissipate the landing loads
before they enter the fuse.
However, I have proved to my own satisfaction that the landing loads are not
the main problem, the braking loads are.
Fitting a one piece gear will not help the braking loads at all and will be
only a minimal improvement.
Alister
Elite 611E
