Sent: Thursday, January 15, 2009 9:23 PM
Subject: Re: [rebel-builders] Rebel Parking Brake
Hey Walter,
Are you aware of any other Rebels flying with the 360? Craig walls
Original Message:
Date: Thu, 15 Jan 2009 14:14:59 -0800
In all my flying so far, can't say that I have ever really needed a
parking
brake (except on water, many times...). Closest I came to that was a few
years ago, on a refuel stop in Hana Alberta, where the wind was blowing
like crazy as I was trying to pull up to the fuel pump. I had to park
somewhat sideways, so the wind wasn't pushing it backwards on me as I was
getting out. Then I had to find some chocks quickly, and put the locks
into
my amphib front gear before they went down on me. Anyway, did manage OK,
and that really was a worse case scenario.
Anyway, Terry, good to see that you are working on your Rebel again.
Instead of inventing more work for yourself, get it finished... Or is that
Bikini team sidetracking you too much...
Date: Thursday, January 15, 2009 1:45 pm
Thanks Wayne, Bob, Charlie, Ken and the rest about the need for
a parking brake valve in a rebel.
Seems for the past 21 years, I have been performing my Long-EZ
parking routine with no need for a parking brake. Just stop the
prop, lower the nose, chalk the main gear tires and tie her
down. No need for parking brake there.
On the Rebel, a parking brake system is probably not a
necessity, but sounded like a good idea to me. Sooooo, I think
that I will purchase a valve and necessary hardware and give it
a try. The cons are that it will add build time, weight and
complexity which goes against my building philosophy. Also there
will be more places for potential leaks or hose failure.
Thanks for the "heads-up" reminder on releasing the brake after
all is secure and tied down on the ramp. That item will go on my
post-shutdown checklist.
As far as accidentally landing with the parking brake "ON" (not
a good idea), I was thinking of a "T" handle in the center top
of the instrument panel, near throttle or the lower left side
panel hitting my knee when "engaged" so you can't miss the
position of said handle. In addition, a micro switch at the
valve body lever with red blinking LED light on the instrument
panel near the handle to advise of a "BRAKE ENGAGED" status.
Oh, yeah, Wayne. I am not married, but I asked my ground crew,
the "Swedish Bikini Team", about holding the airplane while I
chalk the tires. They just told me that they don't do ramp
chores. :)
Thanks again!
Over-and-out . . .
Terry Dazey
Rebel 662
-----Original Message-----locked on a hotFrom: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
Sent: Jan 14, 2009 3:15 PM
Fly with your wife... make her hold the airplane !
Other than that wheel chalks or the tie down area... brakesor lines IMHO.summer day on the ramp is asking for blown calipers andthree years ago.----- Original Message -----
To: "Rebel Builders" <rebel-builders@dcsol.com>
Sent: Wednesday, January 14, 2009 6:11 PM
Subject: [rebel-builders] Rebel Parking Brake
theinstalled
myhosting.com - Premium Microsoft
