have. But when you send them it will create a very large file of garbage
in the archives. Because of this my anonymous FTP site allows uploads. If
you go to ftp.dcsol.com and log in as anonymous, you will be able to
changed to the murphy-rebel directory and upload your photos there. This
will allow everyone to see them, and allow you to place a "link" to them in
your message that will function properly in the archives as well. If you
are not familiar with FTP, I have an FTP program available for download in
the root of my FTP site. This program looks an functions similarly to
Windows Explorer. For you Linux guys (bobp), if you don't know how to FTP,
then your kidding yourselves running Unix! :-) (hint - type "man ftp")
I'm sorry for this inconvenience, but just last week I was contacted by the
sales department of the company that wrote my mail server software. They
want over $1000 to update me to the current release. My feeling is that
not being able to see attachments in the archives is a small limitation
when otherwise it seems to run very well.
At 09:59 PM 10/10/00 -0700, you wrote:
*-----------------------------------------------------------------------------------*What's wrong with sending pictures to this list? I know some cannot receive
them, but if the pictures are not included, then no one can see them.
Everyone loses because of a handicap of a few. As the saying goes, one
picture is worth a thousand words. The pictures that have been posted in
the past were great and I hated to see them stop. Using an FTP site for
pictures is an archane workaround with todays readily available, modern,
email software. I say, send them.
My 2 cents worth. Sorry for the rant.
- Chuck Skorupa -
To: "(Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Sent: Tuesday, October 10, 2000 7:46 PM
Subject: SR. Stab Ribs Denting Skin's Leading Edge
itI just sent the E-mailed below to Murphy Support.
I figured I would pass it on to the list at the same time.
A few minutes ago I sent this to the list with the attachment photos, butamdid not seem to get through. (Attachments not allowed on the list?) So Istructure.sending it without the photos. I think the situation is still clear.
Any suggestions welcome, thanks,
Don
Hi guys,
Hope all is well.
You will find attached two JPEG pictures. One shows denting at the leading
edge of the stabilizer skin. It is occurring top and bottom on all rib
locations. The very front tip of the leading edge ribs is causing the
denting. See picture of leading edge rib.
The skin was installed using the pilot holes and all went well except for
the denting. My conclusion is that the skin's "radius" at the leading edge
is not quite "full" enough or the nose of the rib is not sized right.
The stab is ready for final riveting of the skin to the spar/ribplacingDo you have a fix to relieve the pressure the leading edge ribs arehalfon the skin? I am confident that I can remove the dents if we can "fix the
ribs". Structurally I don't think there is a problem leaving the dents but
aesthetically it would look like hell. They are very obvious in the right
lighting ... hard to miss.
My thoughts:
1. I am not sure if filing back or cutting the tip of the rib will do the
job.
2. Drill a #30 hole just below the flange radius on the web of the ribaway between the two holes on the front flange segment (rib tip). Then make*---------------------------------------------------------------------------cut from the front of the rib just below the radius to the #30 hole. This
would allow the front part of the rib's flange to flex "inward" relieving
the pressure and allowing the skin to make a smooth transition on the rib.
Negative of this approach ... this would seem to destroy most, if not all,
the strength provided by the very tip and the first rivet on the rib.
Help, thanks,
Don Boardman
Rome NY
SR#130
--------**---------------------------------------------------------------------------The Murphy Rebel Builders List is for the discussion
