The Champion CH-48XXX-1 series are a bit shorter than the original
without the -1 number
Dick Wampach SR-108
On Behalf Of srwhitenect@dcsol.com
Subject: [rebel-builders] Straight Oil Filter Adapter
Know this subject has been beaten to death in the past but is there a
new stubby oil filter out that will clear the firewall with the Lyc
straight adapter on an 0-320? Subject came up from a builder friend of
mine who was advised by MAM that there is one available. If so from whom
and the part number if know would be appreciated. Thanks to those that
respond.
Steve W 637R
You can also use KD filter , I will look up the number and mail it to you.
This filter is suppose to be better than the champion
cheers
Hans
640E
On Fri, Dec 5, 2008 at 3:53 PM, <srwhitenect@dcsol.com> wrote:
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
cheers
Hans
640E
--Know this subject has been beaten to death in the past but is there a new
stubby oil filter out that will clear the firewall with the Lyc straight
adapter on
an 0-320? Subject came up from a builder friend of mine who was advised by
MAM that there is one available. If so from whom and the part number if
know
would be appreciated. Thanks to those that respond.
Steve W 637R
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Hi I gave you the wrong onfo yesterday regarding the oil filter for the
0-320
I am using a KN Filter HP-1002. You can get it at Canadian Tire.
Google it and have a read.
It is really stubby and space saving
good luck
cheers
Hans
On Fri, Dec 5, 2008 at 4:58 PM, Richard Wampach <rwampach@comcast.net>wrote:
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
0-320
good luck
cheers
Hans
--The Champion CH-48XXX-1 series are a bit shorter than the original
Dick Wampach SR-108
respond.
Steve W 637R
Hans Kuck
P.O.Box 2212
Sechelt B.C.
V0N 3A0
Canada
Thanks Hans
I'll pass the info onto Ken
Steve > Date: Sun, 7 Dec 2008 10:05:43 -0800> From: hansk3d@gmail.com> To: rebel-builders@dcsol.com> Subject: Re: [rebel-builders] Straight Oil Filter Adapter> > Hi I gave you the wrong onfo yesterday regarding the oil filter for the> 0-320> I am using a KN Filter HP-1002. You can get it at Canadian Tire.> Google it and have a read.> It is really stubby and space saving> > good luck> > cheers> Hans> > On Fri, Dec 5, 2008 at 4:58 PM, Richard Wampach <rwampach@comcast.net>wrote:> > > The Champion CH-48XXX-1 series are a bit shorter than the original> > without the -1 number> >> > Dick Wampach SR-108> >> >> >> > On Behalf Of srwhitenect@dcsol.com> > Subject: [rebel-builders] Straight Oil Filter Adapter> >> > Know this subject has been beaten to death in the past but is there a> > new stubby oil filter out that will clear the firewall with the Lyc> > straight adapter on an 0-320? Subject came up from a builder friend of> > mine who was advised by MAM that there is one available. If so from
whom> > and the part n
u
mber if know would be appreciated. Thanks to those that> > respond.> >> > Steve W 637R> >> >> >> > -----------------------------------------------------------------> > List archives located at: https://mail.dcsol.com/login> > username "rebel" password "builder"> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com> > List administrator: mike.davis@dcsol.com> > -----------------------------------------------------------------> >> >> >> >> >> >> > -----------------------------------------------------------------> > List archives located at: https://mail.dcsol.com/login> > username "rebel" password "builder"> > Unsubscribe: rebel-builders-unsubscribe@dcsol.com> > List administrator: mike.davis@dcsol.com> > -----------------------------------------------------------------> >> >> >> >> > > -- > Hans Kuck> P.O.Box 2212> Sechelt B.C.> V0N 3A0> Canada> > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "reb
Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
u
Thanks Dick
I'll forward ur message to Ken.
Steve> From: rwampach@comcast.net> To: rebel-builders@dcsol.com> Subject: RE: [rebel-builders] Straight Oil Filter Adapter> Date: Fri, 5 Dec 2008 16:58:51 -0800> > The Champion CH-48XXX-1 series are a bit shorter than the original> without the -1 number> > Dick Wampach SR-108> > > > On Behalf Of srwhitenect@dcsol.com> Subject: [rebel-builders] Straight Oil Filter Adapter> > Know this subject has been beaten to death in the past but is there a> new stubby oil filter out that will clear the firewall with the Lyc> straight adapter on an 0-320? Subject came up from a builder friend of> mine who was advised by MAM that there is one available. If so from whom> and the part number if know would be appreciated. Thanks to those that> respond.> > Steve W 637R > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: m
--------------------------------------------------------------> > > > > > > -----------------------------------------------------------------> List archives located at: https://mail.dcsol.com/login> username "rebel" password "builder"> Unsubscribe: rebel-builders-unsubscribe@dcsol.com> List administrator: mike.davis@dcsol.com> -----------------------------------------------------------------> > >
