Configuration looks like. Would be much appreciated.
G. O'Shea
Sent: Sunday, November 30, 2008 12:10 PM
Subject: [rebel-builders] Control column push rod to bellcrank modification
for full rotation
That's something common we've been doing for 15 years Eric... cut two slices
of 5/16" OD x1/4" ID tube about 3/16" long. Put one between the bellcrank
and rod end ball and the other on top of the ball capped with a penny
washer. (I like to use AN970-3's drilled to 1/4").
This way you can lock nut both rod ends on the push pull tube and the small
slices of tubing will let the rod end ball rotate further in the rod end. I
find a piece of 1/4" ID stainless brake line works great for this.
Sent: Sunday, November 30, 2008 4:17 AM
Subject: RE: [rebel-builders] Elite Instrument Panel - Dynon
Good spot on the penny washer. You are correct, it is missing on this ball
end. Penny washers are in place on rod ends elsewhere on the plane.
This particular rod end should be okay without. I'm not sure if this is a
unique problem on the Elite, but this rod end has interference problems.
If
installed per the manual, the rod end hits the bell crank arm and causes
rotation in the rod threads; a definite long term wear problem as the
steel
rod end threads turn in the aluminum push tube end.
A bushing is needed to raise the ball slightly above the bell crank arm so
there is no interference. A penny washer might be okay on top now, so I'll
double check.
I'll work on that paint job in February.
Patterson
Sent: Saturday, November 29, 2008 9:25 PM
Subject: Re: [rebel-builders] Elite Instrument Panel - Dynon
Looks good Eric ! Very tidy !!! Your Elite is now part of the web
site
slide show - look forward to featuring it again when it's painted.....
It'd be nice if those Elite drivers who complained about possible lack
representation for Elites would send even ONE picture of THEIRS !
I don't have any new ones ...
Looking down in the bottom left of the picture, I think I see a
possible problem -- although it might be just my eyes, or the picture....
I'm looking at that ball end on the pushrod coming out of the control
stick - it doesn't seem to have penny washers on both sides ....
It is a "Really GOOD idea"(tm) to put penny washers on each side
of ALL ball ends on pushrods - especially for ailerons & flaps ....
In a few years, if that ball wears, it might just pop out - and right
off the bolt !! That can spoil your afternoon .....
The penny washers keep the rod captive, even if the ball fails ....
Just a thought .... hope it helps avoid some trouble !
bobp@prosumers.ca
