If anyone were interested in increasing the compression in that engine I've
a set of 0-360 std. pistons and rings with hardly any run time on them. I
put them in briefly then bored to .010 over.
To: "Murphy Rebel Builders List" <rebel-builders@dcsol.com>
Sent: Wednesday, November 26, 2008 6:06 PM
Subject: [rebel-builders] Lycoming O-320-A2B available..
Is anyone on the list considering building up your own O-320 x 150HP....
learn and save some labour dollars? And doesn't want to roll the dice or
play CRAPS.. buying someones TBO'd engine?
If you are send me an email directly ASAP, before I start parting this out
on Ebay. oifa@irishfield.on.ca
I have a disassembled / cleaned / NDT inspected (by certified facility -
ATC) O-320-A2B Narrow Deck.... pretty much complete including freshly
chromed to std size cylinders with the valves and guides done and
installed
/ pistons c/w new rings already gapped and installed. (Cylinder chroming /
rings / valve work worth $2200 alone... not counting the $960 for
Disassembly, Clean and inspect)
I picked this and the remainder of my engine stuff up from ATC yesterday.
Still going thru it all to put together a complete engine for someone to
build up. If anyone is interested let me know. As like I said it's going
go piece meal on Ebay if nobody wants a package. Looking to get my $3480
for
current work out of this and something fair in the way of $'s for the
original core. Have perfect cam, new lifter bodies etc to go with it. Have
carb you can rebuild or for extra money one that's already overhauled
ready
to go. Crank flange is straight and current bearing surface wear is
measuring about 2 thou from STD size. Has some pitting on the thrust
bearing
area, but should come clean enough to use with a 10thou grind and
renitrate.
Accessory case has provision ports for vacuum pump / governor / fuel pump
if
you wanted to use any of those items.
