Hi Jason
As you're drilling it from the fuselage, use the strong screw down type
cleco's to hold it in place rather than the normal spring ones - I messed my
initial ones up as the holes started going out of alignment when I started
riveting the panels in place after drilling :-(
Nigel
745E
Rebecca Brownell
Sent: 08 November 2008 16:16
Subject: [rebel-builders] bottom corner wraps(bulkhead A)
Hi all
Having a deuce of a time trying to get the wraps between bulkhead A
and F bent properly to make the transition from the cabin
to the tail cone.Any helpful tricks out there?Any help would be
appreciated.
Jason
817R
I used both strecher -shinker and a baseball bat and it did a great job the
strecher-shinker does mark it up but with a scotch bright disc buffed out
sratches.
Bill
Moose 244
Sent: Saturday, November 08, 2008 11:15 AM
Checked by AVG - http://www.avg.com
Version: 8.0.175 / Virus Database: 270.9.0/1775 - Release Date: 11/8/2008
9:56 AM
sratches.
Bill
Moose 244
--------------------------------------------------------------------------------Hi all
appreciated.
Jason
817R
9:56 AM
I tried using my shrinker-stretcher but it didn't work well at all. In fact,
I have had very little luck using my shrinker-stretcher on anything except
flanged parts like ribs or channels. I eventually ended up bending it with a
simple pair of pliers working slowly along the curve. I protected the metal
with a cloth but it still got marked up a bit.
Rebecca Brownell
Sent: Saturday, November 08, 2008 7:16 AM
Hi all
appreciated.
Jason
817R
Rebecca Brownell
Hi all
appreciated.
Jason
817R
Jason.. I find you need to do nothing but roll the edge nicely to get a good
fit. Possibly a bit of joggling on the underlying tail cone wrap between
each flange first. But absolutely no need to get out a baseball
bat..shrinker etc. I'll dig thru my fuselage build pics and send you a
couple.
Plates show up yet?
couple.
Plates show up yet?
Hi all
appreciated.
Jason
817R
