Hi Ralph,
I think if I had been flying longer I wouldn't be so impatient to be in
the air! Thanks for the encouragement. Kind of like a support group. Ha
ha
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of Ralph
Baker
Sent: Monday, October 06, 2008 5:54 AM
Subject: [rebel-builders] "newer" builder
Craig,
As a 10+ year builder of a 95%? Elite, keep at it every day. (Should take
my own advice!) Try to envision the future results of each step and do all
the work in a timely fashion. Sometimes wiring or systems are more easily
installed at an earlier or later point in the construction. Also, do make
modifications that will allow later maintenance to be easier. An example is
the suggestion to add interior nut plates for flaperon hinges. Another is
to add access plates to allow later replacement or wiring inspection in
otherwise difficult areas.
